Pico scope
- Andreastech
- Thank you received: 8
8 years 10 months ago - 8 years 10 months ago #15943
by Andreastech
Pico scope was created by Andreastech
Hello ... today i order a cheap 2 channel 2000 series pico scope,
to see how it works, make basic tests etc ... and to see the software in action
as scannerdanner and Tommy from positive lead diagnostics and others are using !!
Any tricks and suggetions are very welcome guyz
ofc i have saw some Paul's premium scope training videos to get some better ideas ...
P.S to test secondary ignition will need attenuator i think ... correct ?
Last edit: 8 years 10 months ago by Andreastech.
- EricGoodrich
- Thank you received: 49
8 years 10 months ago #15960
by EricGoodrich
Secondary ignition on vehicles with wires is observed with a capacitive pickup. No attenuator needed. Secondary ignition on COP ignition systems is observed with a COP probe. No attenuator needed.
Two things, mainly, are going to require an attenuator; primary ignition coil voltage and fuel injector voltage. Both of those are capable of producing exceedingly high voltages that can damage the scope. In those cases an attenuator is necessary.
Replied by EricGoodrich on topic Pico scope
Andreas81 wrote: Hello ... today i order a cheap 2 channel 2000 series pico scope,
The following user(s) said Thank You: Andreastech
