Verus how to save oscilloscope file
- River basin
2 years 7 months ago #64993
by River basin
Verus how to save oscilloscope file was created by River basin
Hi and thanks for looking at my question. Struggling with use issues on a Snapon Verus D10. It has software update through 2018. After I get a diagnostic file created on the scope, I try to open file save tool and create the file. Later, as I try to sit down and analyze what isn't making sense, I see the saved .GSM file. But nothing opens that is a video file. I saved a couple files on this COP analysis against my no. 1 cylinder.
I am trying to see misfires against the amperage off the 30A circuit that has the COP fire. vehicle is a '02 Ford E350 with 5 4L
The question is about the quirky nature of Verus, and if this is a memory problem, or a file type mistake?
I will be thinking about my next scope. Waste a LOT of time working with this tool.
2 years 7 months ago #65000
Replied by Noah on topic Verus how to save oscilloscope file
Shop stream connect is the software that will open the .vsm files on a computer for viewing.
Sometimes my Verus will put the scope viewer window off screen when I try to go back to my captures.
There's a way to get it back on the screen. I think right clicking the tool bar, chose view active tabs and cascade all tabs (or something like that) will bring everything onto the windows home page.
- River basin
2 years 7 months ago #65033
by River basin
Replied by River basin on topic Verus how to save oscilloscope file
OK, took some fumbling but I did figure that out. I was hoping to share a .gsm scope file on here, but don't see that as an acceptable extension. Anyone tell me a way to do that? Maybe link it to outside location?
- River basin
2 years 7 months ago #65034
by River basin
This is a COP fire on green and no.1 on yellow. I know it doesn't look right. Maybe someone can tell me something to change. I have the amp clamp on 1 volt. I should see 8 pronounced fire spikes on that green pattern. The vehicle type is a 02 Ford E350 with a 5.4 Triton. I am on the fuse block (passenger) on the 30 A that is suppossed to be for the COP on this vehicle. The fuse block is different than a F150 of same period.
2 years 7 months ago #65038
You can take a screen shot of the part of the waveform you want to show and insert it as a JPG or PNG. You could also put the
.vsm in Google Drive and share link here, then anyone with Shop Stream software can open and manipulate the entire waveform.
- River basin
2 years 7 months ago #65157
by River basin
Have a successful test, but engine ran decent. May need to repeat on a fully hot 30 mile drive. This screen image happened on my problem cylinders with the misfire. What does that downward spike tell you?
2 years 7 months ago #65158
Just looks like ignition related noise to me, not an indication of a fault.
They always happen right when the ramp stops, that's right when the spark takes place, so at least to me, it seems logical that you might pick up some noise in that portion of the waveform.
