valve events, in cylinder ?
  • stevieturbo
  • stevieturbo's Avatar Topic Author
3 years 2 months ago - 3 years 2 months ago #62780 by stevieturbo
valve events, in cylinder ? was created by stevieturbo
ust a query about pinpointing valve events, idling engine, not a standard engine, uprated cams...however bizarrely whoever has built the engine fitted the cam marked exhaust....on the inlet side, and the cam marked inlet, on the exhaust side. genius.
They are probably asymmetrical profiles, so if timed correctly, should not be an issue. However....I just feel something is amiss.
GM 2.2, 4cyl DOHC, Comp cams
As the overlap area is likely to be of little use...I assume EVO and IVC points should be relatively easy to get close ?
So approximately, EVO occurs around 154deg, and IVC around 583 deg ?
IVC seems fairly reasonable. EVO really does seem extremely late. Or am I totally wrong on the positioning ?
Last edit: 3 years 2 months ago by stevieturbo.
3 years 2 months ago #62782 by juergen.scholl
Replied by juergen.scholl on topic valve events, in cylinder ?
154 degrees for EVO is not out of order.
You may want to lower the voltage scale in the capture so the pressure changes stand out more pronounced. In the picture your ruler may be placed slightly later than the pressure change occurs.
The valve actually opens before the in cylinder pressure change goes up, you may want to run the Px script to get more precise data.
Here is an interesting read:
forum-injectorservice-com-ua.translate.g...en-US&_x_tr_pto=wapp
  • stevieturbo
3 years 2 months ago #62783 by stevieturbo
Replied by stevieturbo on topic valve events, in cylinder ?
Thanks, so not quite as easy to pinpoint the valve events as I'd hoped.
I'll just have to wait a couple of months til I can get it apart properly to check the cam timing.
Just bizarre someone would put them in the wrong places....it's not like they are clearly marked intake and exhaust !!! lol
Probably symmetrical anyway, but if they used the wrong timing, the overlap would be a few degrees different, as well as overall timing for each cam
