Autel Maxiscope with hantek ht25 cop question
- tontsa
3 years 6 months ago #61314
by tontsa
Autel Maxiscope with hantek ht25 cop question was created by tontsa
hi, I just got a hantek ht25cop for my maxiscope. I was wondering about what scaling should I use with it so I could get somewhat "accurate" kv readings? Also has anyone any inside about why this secondary capture looks so weird? car is 2005 Volvo with 4-wire coil, running fine.
Thanks for your help!
- juergen.scholl
- Active partschanger
- Thank you received: 462
3 years 6 months ago #61316
by juergen.scholl
Replied by juergen.scholl on topic Autel Maxiscope with hantek ht25 cop question
Probably you won't find a general formula to translate your probe's measurements into an accurate kV reading, for quite a couple of reasons.
You always can put a regular ht lead between coil and plug and measure now with a regular capacitive probe.After comparing these readings to the measurements from your ht 25 on the same cylinder you now can create a custom probe.
Your capture looks strange, indeed: it gives the impression that dwell time and burn time are side shifted. What's left of the supposed inductive kick (happening earlier) looks definitely like a spark line and is shorter than what's right of it. Typically the dwell period is longer than the burn time, your capture shows this different...
A cop coil typically is negatively fired and your scope may not be (looks like) configured to compensate for this: this will result in an upside down image. Portions of your image point to this.
- tontsa
3 years 6 months ago #61319
by tontsa
Replied by tontsa on topic Autel Maxiscope with hantek ht25 cop question
thank you!
Do you have any ideas or tips what I could do for to make this cop probe more useful?
- juergen.scholl
3 years 6 months ago #61321
by juergen.scholl
You may try the following :
Use the invert function in the channel settings, apply a shorter time base (1 or 2ms/div using a trigger) and play around with the paddle position to find the best position/image.
