Using a battery saver?
- dennis524
- Thank you received: 2
4 years 8 months ago #54453
by dennis524
Using a battery saver? was created by dennis524
Hi all,
I was wondering when using a battery saver is it safe to disconnect modules and sensors
without the risk of damage? Or are they used strictly to keep things alive so you don't loose any settings
when changing batteries?
Thanks for you help.
Dennis
Dennis
4 years 8 months ago - 4 years 8 months ago #54461
Replied by Andy.MacFadyen on topic Using a battery saver?
It isn't any different from pulling a module with the car battery connected. the ignition should be switched off and key removed,
The big warning is be careful with any temporary connection and make sure the disconnected car battery B+ dosen't short to ground
I use a rubber glove or old radiator hose to insulate the battery lead.
Last edit: 4 years 8 months ago by Andy.MacFadyen.
- dennis524
4 years 8 months ago #54462
by dennis524
Replied by dennis524 on topic Using a battery saver?
Ok, Thanks!
