t pin size
  • DapperZapper
  • DapperZapper's Avatar Topic Author
5 years 6 days ago #52355 by DapperZapper
t pin size was created by DapperZapper
are these a good "girth" for back probing?
www.staples.com/Staples-10819-CC-Nickel-...MlZ-BdhoC6ksQAvD_BwE
  • DapperZapper
5 years 6 days ago - 5 years 6 days ago #52356 by DapperZapper
Replied by DapperZapper on topic t pin size
actually, office max is a lot closer to my house than staples.  they have 3 different t pins.  the only meaningful difference in spec i can see is that one pack is 2" and the others are 1.5".  is 1.5" long enough for most things?  i'm guessing shorter is also thinner...
www.officedepot.com/catalog/search.do?Ntt=t+pins
edit:  looks like the only ones local are the brass looking ones that are labeled "chrome" color and are 2" in length.  good enough?
edit redux:  my local walmart has these.  only 1.75".  good enough?
www.walmart.com/ip/Dritz-T-Pins-40-Count...illmentIntent=Pickup
last one i swear:  amazon.  looks like they ahve all sizes covered, but there is uncertainty of what kind of "High-Quality Metal" they are using.  does it matter?
www.amazon.com/Mr-Assorted-T-Pins-Blocki...ZR190&srpt=SHARP_PIN
Last edit: 5 years 6 days ago by DapperZapper.
5 years 6 days ago #52357 by AJeep18
Replied by AJeep18 on topic t pin size
I don't think it matters as long as they are conducive. I got mine at the local supermarket, work just fine. If you are unsure I would get a variety pack just to be safe.
The following user(s) said Thank You: DapperZapper
5 years 6 days ago - 5 years 6 days ago #52358 by Noah
Replied by Noah on topic t pin size
That box from Amazon will do the trick.
I personally prefer back probes over T pins, these are the ones I use every day. I have others, as well as some T pins, but these are my favorite.
www.aeswave.com/uMicroBackProbe-Minimum-...onnectors-p9481.html
Last edit: 5 years 6 days ago by Noah.
The following user(s) said Thank You: Tyler, DapperZapper
5 years 6 days ago #52360 by Tyler
Replied by Tyler on topic t pin size
Second the uMicroBackProbe set. They're the only thing I use to backprobe any more.
  • DapperZapper
5 years 4 days ago #52392 by DapperZapper
i like that design because there is less "unsprung mass" to put torque on the connector socket and deform it. but i don't like how the insulation goes nearly all the way to the tip. i'd think that would make it quite a bit thicker and cause more stress on the weather seals as you're pushing past them.
5 years 4 days ago #52395 by Noah
The insulation really doesn't get in the way. It's just heat shrink tube, you can strip it back.
  • DapperZapper
4 years 11 months ago #52600 by DapperZapper
aes wave doesn't say on the web page whether those are shrouded male or unshrouded female banana connections. which is it?
4 years 11 months ago - 4 years 11 months ago #52604 by Tyler
They're shrouded female. See the attachment for a similar example.
Last edit: 4 years 11 months ago by Tyler.
4 years 11 months ago #52713 by AguilarPro
Replied by AguilarPro on topic t pin size
I personally bought these T-pin varied sizes:
www.amazon.com/gp/product/B01M4O1TKD/ref..._title?ie=UTF8&psc=1
and I custom made my own pins by buying the 2mm banana along with the 3mm banana female & male plugs. I don't use the male plugs since the females are what will be needed for any test lead wire. I have used the male plugs to make extensions to jump to ground, etc. The way I make my pins were similar to this guy on Youtube:
