Re:In cylinder pressure transducer hose
- Ben
- Thank you received: 215
5 years 2 months ago #50770
by Ben
In cylinder pressure transducer hose was created by Ben
Ive been using the hoses from my digital compression tester for in cylinder I just don't like using them... I'm sure there's some really nice ones out there I like the steel braided 1 Bernie uses but haven't seen them online and there probably expensive... soooo I made some! I've seen the solid aluminum 1s from questionable Chinese sources and I liked the idea of the hose not expanding but after making it I found it really lacked the flex for v engines soo I made 1 of 3250 psi hydraulic hose unfortunately I could not find off the shelf hydraulic ends for the spark plug thread so it had to be customized... I'll get some pictures of it in use next time I hook it up. Also im using an ac pressure transducer (idea from Tutti57 ) which gives amazing signal quality! Unlike those crappy eBay transducers...
The following user(s) said Thank You: Noah, Wightscope
5 years 2 months ago #50771
Replied by Noah on topic In cylinder pressure transducer hose
Nice, i'm still using my compression gauge hoses with the AC pressure sensor, looking for something better.
- Ben
5 years 2 months ago #50772
by Ben
Replied by Ben on topic Re:In cylinder pressure transducer hose
5 years 2 months ago - 5 years 2 months ago #50773
Replied by Noah on topic Re:In cylinder pressure transducer hose
That has been the topic of discussion in a couple of the Zoom meet ups on Saturday nights. Looks like a fine tool, i've been tempted myself. Perhaps Jurgen will chime in.
Last edit: 5 years 2 months ago by Noah.
- juergen.scholl
- Active partschanger
- Thank you received: 462
5 years 2 months ago #50820
by juergen.scholl
Replied by juergen.scholl on topic Re:In cylinder pressure transducer hose
I have it, I use it, I like it. Almost a 1:1 clone of the WPS, one difference is the high resolution range where the max. negative pressure isĀ 2.5 psi instead of 5 psi.
There's also an informative video on you know where....
Time to create page: 0.346 seconds
