Back pressure testing
- agorapocalypse90
5 years 3 months ago #50422
by agorapocalypse90
Back pressure testing was created by agorapocalypse90
Hello I was trying to see if anybody had any input on a preferable temp. When doing a exhaust back pressure test to get best results. I wouldn't think it would matter if the engine was cold or hot but just was wanting to see what the general consensus was
5 years 3 months ago #50456
Replied by Andy.MacFadyen on topic Back pressure testing
If it is blocked it is blocked and won't care about the temperature.
Most times if you are doing it at the O2 sensor you don't even need to put a gauge on it you will feel difference as soo as you remove the sensor.
5 years 3 months ago #50458
Replied by Noah on topic Back pressure testing
I agree with Andy, temperature shouldn't effect the results. However, it's usually best to test for any fault under the conditions that the fault presents itself. So if it runs poorly hot, I'll check it when it's hot
