Instead of blowing fuses.....
  • juergen.scholl's Avatar Topic Author
5 years 3 months ago - 5 years 3 months ago #49989 by juergen.scholl
Instead of blowing fuses..... was created by juergen.scholl
An easy to make set-up with the possibility to wrap an amp clamp around and measure current.
Last edit: 5 years 3 months ago by juergen.scholl.
5 years 3 months ago #49991 by Dtnel
Replied by Dtnel on topic Instead of blowing fuses.....
The white switch is for?
Had the thought when I saw that... What if you tied a relay testing mechanism into it?
Maybe where you can removed one end then add the relay mount for the appropriate relate? Maybe a little over thought but just something that came to mind as well. Kind of like a "all in one" universal tool....
5 years 3 months ago #49992 by juergen.scholl
Replied by juergen.scholl on topic Instead of blowing fuses.....
The switch just allows to open/close the circuit to control current flow. Personally I prefer a seperate "tester" to check relays just to make it not too bulky.
5 years 3 months ago #49995 by Noah
Replied by Noah on topic Instead of blowing fuses.....
Nice, I like it :)
