Desired vs measured readings
  • Takeeon
  • Takeeon's Avatar Topic Author
5 years 6 months ago #48579 by Takeeon
Replied by Takeeon on topic Desired vs measured readings
I believe it's a variable twin scroll borgwerner
5 years 6 months ago #48580 by RimmersTechSWE
Replied by RimmersTechSWE on topic Desired vs measured readings
"Back pressure" would be a negative value though. Unless they compensate a car with the key on and engine off should be a 1 atmosphere unless it's compensated to 0. Any positive exhaust pressure should push exhaust gases out of the exhaust and any negative pressure should suck them back in again. The more throttle the more positive pressure. "Back pressure" should only be posible in a 4 stroke exhaust if it had a leak to the intake through a permanently open open EGR. That would also explain the exhaust pressure being lower with the engine running. Strange if it didnt set a code though. That's unless there is any other path for exhaust gasses to get into the intake.
  • Takeeon
5 years 6 months ago - 5 years 6 months ago #48598 by Takeeon
Crap. I've got to look into this further
Last edit: 5 years 6 months ago by Takeeon.
5 years 6 months ago #48601 by Matt T
Replied by Matt T on topic Desired vs measured readings
RimmersTechSWE wrote: Yeah the anomaly is almost exactly 1 atmosphere of pressure so it looks like there is some calculation error. That upstream throttle sensor might be a dead end.
Actual is definitely absolute pressure because it's ~ BARO KOEO. The desired is less than BARO so it might be gauge pressure??
  • Takeeon
5 years 6 months ago #48603 by Takeeon
What exactly to do you mean by "guage pressure"?
  • Takeeon
5 years 6 months ago #48604 by Takeeon
Oh, I see what you mean. That wouldn't add up either. The odd thing is that it smooths out when both numbers even out. That makes me think the desired is absolute as well
  • Takeeon
5 years 6 months ago #48605 by Takeeon
Seen here at about 3.5k. This is usually when the car feels like it flips a switch and starts to pull normally. It runs like garbage mostly when I see the numbers out of alignment. This is the only quantitative thing I've found that shows when it runs well and when it doesn't.
  • Takeeon
5 years 5 months ago #48699 by Takeeon
It looks like the readings for "desired" are mirroring absolute intake manifold pressure. So what the hell is it measuring?!
