Key Off Draw
5 years 7 months ago - 5 years 7 months ago #47917 by Noah
Key Off Draw was created by Noah
This will be quick, just wanted to share the latest key off battery draw complaint I had.
Once I was hooked up I could see there was nearly 5 amps of current!
Anything pulling that kind of load should have been obvious, but no lights were on, no motors or pumps were running, so the first test I did was disconnect the B+ cable from the new alternator:
And after about 30 minutes it fell down to about 20ma.
Last edit: 5 years 7 months ago by Noah.
5 years 7 months ago #47919 by Tutti57
Replied by Tutti57 on topic Re:Key Off Draw
Good find. Did you busy happen to check it after you installed the alternator or did something happen that led you to test it?
5 years 7 months ago #47921 by Noah
Replied by Noah on topic Re:Key Off Draw
I did not install that alternator, it came in like that.
Just a semi educated guess, plus it was easy to get at :)
5 years 7 months ago #47942 by AJeep18
Replied by AJeep18 on topic Re:Key Off Draw
I’m curious if you have a theory as to what it took so long. It seems to me that as soon as you unhooked the B+ the voltage would have stopped back-feeding and the draw would have gone away?
5 years 7 months ago #47947 by Matt T
Replied by Matt T on topic Re:Key Off Draw
AJeep18 wrote: I’m curious if you have a theory as to what it took so long. It seems to me that as soon as you unhooked the B+ the voltage would have stopped back-feeding and the draw would have gone away?
That does seem a bit weird. Looks like it only dropped to ~1/2 amp when the B+ wire was disconnected. And control wiring appears to have already been unplugged so the alternator couldn't keep anything awake thru' it??
Does the vehicle have a battery current sensor? A 5A reading from it might keep some things awake??
5 years 7 months ago - 5 years 7 months ago #47956 by Noah
It dropped 4.3 amps with the battery feed disconnected, down to 450ma.
Which did seem awful high to me, but I wasn't ready to go digging around the fuse box just yet since I knew the modules all would still be awake because I just started the draw test.
So I went after a crank no start Yukon in the parking lot while I waited for everything to time out.
And you are correct, I disconnected the control harness to ensure it was just the alternator that was the source of the draw and not some weird fault in the control circuit.
Every time I looked back at it (every 10 minutes-ish?) it stepped down consumption more than 10ma. Eventually on one of my passes by the car it had fallen to 20ma.
5 years 7 months ago #47964 by AJeep18
Oh I see, I didn't look at the picture close enough. :blush:
5 years 6 months ago - 5 years 6 months ago #48001 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Key Off Draw
Nice one !
I had that a few years back -- didn't have much in the way of diagnostic equipment at the time so it took me a bit of scratching around. It was an even bigger drain it was a Lucas Magneti Marelli so pulled 3 blade multi plug at the alternator --- big fat spark ! problem found :-)
Now if I see a big current drain I go straight amp clamp the alternator and wiper motor first.
Last edit: 5 years 6 months ago by Andy.MacFadyen.
5 years 6 months ago #48002 by Wightscope
Replied by Wightscope on topic Key Off Draw
Must be one of those new cold start aids that keeps the engine bay warm !
Good find.
5 years 6 months ago #48031 by Noah
Replied by Noah on topic Key Off Draw
Yeah, I'm sure the critters under the hood didn't mind cozying up around that thing at night.
