Parasitic Draw with dual batteries
- AJeep18
- Thank you received: 34
5 years 7 months ago #47724
by AJeep18
Parasitic Draw with dual batteries was created by AJeep18
Working on tracking down a draw on a f250 with dual batteries. I connected my amp meter between the negative terminal and the negative post of the battery, but I got to thinking, there is another ground still attached so is all or half of the current traveling through that ground instead? should i completely unhook that one and measure at the first one?
5 years 7 months ago #47742
Replied by Tyler on topic Parasitic Draw with dual batteries
I'd also love some clarification on this one. :lol: I've never been clear about correct draw testing on dual battery systems.
5 years 7 months ago #47751
Replied by Noah on topic Parasitic Draw with dual batteries
It may or may not be the "right" way to do it, but I always go for the one closest to the fuse box. It's always been my assumption that if it's dual battery, 12 volt system, the amperage has to flow through your meter either way.
- Ben
- Thank you received: 215
5 years 7 months ago #47767
by Ben
Replied by Ben on topic Re:Parasitic Draw with dual batteries
No disconnecting only 1 battery will not give you accurate draw reading
5 years 7 months ago #47803
Replied by Andy.MacFadyen on topic Parasitic Draw with dual batteries
I take it is not split charge --- you will really need to disconnect one with only battery at a time testing for and test each battery for a dead/shorted.
ISTR Eric O videoed an issue with a dual battery set up on a snow plow a couple years back.
