Pulse Sensor?
  • AJeep18
  • AJeep18's Avatar Topic Author
5 years 8 months ago #47176 by AJeep18
Pulse Sensor? was created by AJeep18
So I have been learning a lot recently about how helpful pulse sensors can be ( both in the intake and the cooling system) and I was looking at purchasing or making one. I have seen the videos making one from a smoke detector, but I was wondering would an old MAP sensor work? Then I got thinking if that was the case... why doesn't everyone just backprobe the signal wire on the MAP? Does it not have the detail required for something like that? Just curious.
5 years 8 months ago - 5 years 8 months ago #47187 by Wightscope
Replied by Wightscope on topic Pulse Sensor?
Using a MAP sensor would need a 5v stabilised supply. Much easier to buy a $2 piezo sensor off ebay and stick it in a container with a pipe on the end and a BNC on the other.
I have an old MAP sensor sitting on my desk waiting to be added to my DIY scope tool selection, but I have already built the 5v supply for pressure sensors.
Good point about using the one on the car if it has one and it's accessible
Last edit: 5 years 8 months ago by Wightscope.
5 years 8 months ago #47190 by Tyler
Replied by Tyler on topic Pulse Sensor?
I've tried using the MAP sensor on several different vehicles for intake pulse waveforms. None of them had the same kind of response or detail that a dedicated pulse sensor has :(.
However, I have seen MAP sensors used for head gasket testing with success. There's just the matter of supplying 5V as Wightscope mentioned.
I've made several of my own, but end up just buying one from Cody's Auto Diagnostics. Much better quality than what I could piece together at home.
The following user(s) said Thank You: Wightscope, AJeep18
5 years 8 months ago #47194 by stevieturbo
Replied by stevieturbo on topic Pulse Sensor?
A basic pressure sensor and a pulse sensor are doing two different things though.
5 years 8 months ago - 5 years 8 months ago #47199 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Pulse Sensor?
Think of it this way a MAP sensors is like a doctor checking a patients blood pressure, but a pulse sensor is more like an doctor taking a ECG.
Last edit: 5 years 8 months ago by Andy.MacFadyen.
The following user(s) said Thank You: AJeep18
  • AJeep18
5 years 8 months ago #47200 by AJeep18
Replied by AJeep18 on topic Pulse Sensor?
Ok thanks for the information! I guess I will put one on my shopping list.
5 years 8 months ago #47202 by Tutti57
Replied by Tutti57 on topic Re:Pulse Sensor?
Does cody have an online store to browse?
  • AJeep18
5 years 8 months ago #47214 by AJeep18
Replied by AJeep18 on topic Re:Pulse Sensor?
No, you have to go through his Facebook page
5 years 8 months ago #47220 by Chad
Replied by Chad on topic Re:Pulse Sensor?
www.facebook.com/CodysAutoDiagnostics/
I use the Nicholson Pulse Sensor.
Jarhead Diagnostics is another option.
5 years 8 months ago - 5 years 8 months ago #47221 by Andy.MacFadyen
After messing around with home build ones I bought the Ditex one a few years back
autoditex.com/pressure-pulse-sensor-63.html
5 years 8 months ago - 5 years 8 months ago #47223 by Chad
Replied by Chad on topic Pulse Sensor?
Andy.MacFadyen wrote: After messing around with home build ones I bought the Ditex one a few years back
I don't know what the Ditex costs. But, the first pulse sensor I ever bought was a Firstlook sensor, by SenX Tech. I paid over $400, plus shipping. AESwave now sells them for $350.
A year, or so, later, I decided that I needed a second pulse sensor. I found the NPS on Facebook. The sensor AND a BNC/Banana plug cable for about $100. After using it, I bought another one. Then, I bought 2 more. Now, my poor $400 firstlook sensor, rarely, gets used. NPS is the only sensor, (that I know of) that accepts BNC AND Banana plug.
I believe, all the home built sensors listed above are of very good quality, with many people in the industry currently using them without complaint.
Last edit: 5 years 8 months ago by Chad.
5 years 7 months ago #47256 by ivoalaska
Replied by ivoalaska on topic Pulse Sensor?
I use Rotkee sensor (17 dollars) and it works great.
Time to create page: 0.387 seconds
