Affordable Scope Options
- OldSchool
- Thank you received: 3
My question is what is the cheapest tool or scope that I could purchase to achieve my goal? Please keep in mind: I have both a windows 10 & linux laptop (with wifi and bluetooth) that I could connect to this tool, AND also, the cost of the software, if not included in the tool purchase. I plan to sell this vehicle once repaired.
Thanks!
P.S. Thanks for moving this, Noah!
- YTInnovativeSolution
- Be Innovative
- Thank you received: 8
The other low cost option are one of the DSO Nano scopes these are tiny palm sized devices smaller than most mobile phones The little DSO201 Nano is the cheapest but the firmware loaded when it comes from the supplier is pretty well useless, however the firmware can be upgraded to the free Ben-F firmware which turns it into a brilliant little scope, loading new firmware is very similar to installing a custom android version on a phone.
AesWave sell a special version of the DSO201 with customised firmware specially for automotive use , this firmware is excellent but obiously you will pay a reasonable price premium for their intelectual property and marketing. Both the DSO201 Nano and the Uscope are single channel scopes.
The DSO203 Nano is the next option sold as 4 channel scope it actually only has 2 analogue scope channels I have never tried one but it seems to get good reviews with the original firmware and 2 channels.
The DSO201 and the DSO203 and the basic version of the Uscope come without accesories apart from a basic oscillope probe, but you can find any accessories you need on eBay or Amazon
- OldSchool
sure wish I knew what these things meant in relation to testing an engine sensor. No time for learning that now though. Barely keeping up life...
I would like to know though: If I purchase either of your suggestions, what accessories (such as probes) will I need for my specific task?
BTW, for anyone interested: The DS0 Nanno v1 is about $70 and v3 is about $90 on ebay and the hantek is similarly priced.
Here's an informative link on the DSO nano www.seeedstudio.com/wiki/DSO_Nano
Having two channels is a bit like using two voltmeters or a voltmeter and an ammeter at the same time. You can do at lot with a single channel but two channels are increasingly needed for checking that two signals are in sync for example checking the cam sensor timing against crank sensor, which is much like checking the mechaical timing marks are correctly lined up.
Having a high bandwidth or sampling rate isn't that important for automotive work
Probes are just the tools used to make connections or pick-up signals. Some make a direct contact electrical connection (such as back probes or alligator clips) or use capictance or inductance effects (secondary ignition probes and amp clamps) to pick up a signal.
- mikePSKperformance
If it is worth doing, its worth doing right
- Be Innovative
Andy.MacFadyen wrote: The truth is for all the big words the only real difference from using a scope to using a volt meter is the scope draws a picture of voltage over time. Learning to work one is a bit like learning to use a new TV or smart phone in that you will only ever use less than 1/4 of the features and the only way to learn to use it start pushing buttons to see what happens.
Exactly!! If one becomes familiar with a scope, the ability to use a regular DMM grows exponentially.
- AJeep18
- Thank you received: 34
- marwee
- advancedleveldiagnostics
