Vantage ultra using a 600 amps clamp
  • Gregos
  • Gregos's Avatar Topic Author
5 years 8 months ago #47049 by Gregos
Vantage ultra using a 600 amps clamp was created by Gregos
Hi Paul.is it possible to use a 600 amps clamp on a vantage ultra scope.i want to do a starter cranking test to so that I can see if the armature or brushes are bad. Thanks.
5 years 8 months ago #47057 by Matt T
Replied by Matt T on topic Vantage ultra using a 600 amps clamp
The clamp should work with your Vantage. Just use the appropriate voltage scale.
That said it'll take some playing around with filtering to get a good look at the armature humps. IIRC the Vantage does have filtering but I'm not sure if it's adjustable.
