Longer leads for Snap On Modis Ultra
5 years 8 months ago #46781 by Ferox
Hi all,
I'm using my Modis pretty much everyday but the test leads are to short. I know i can buy longer leads from Aeswave but i'm living in the Netherlands and due to shipping and taxes the price will almost double.
Are there other leads that i can use to lengthen them? Banana doesn't work, i know the Snap On ones are shielded but sometimes is unshielded better than no leads ;).
I can use port 1 with banana but then i can't ground the second port. The other thing i can do is BNC tot banana but i personally hate that solution.
Like to hear your solutions/thoughts.
5 years 8 months ago #46788 by Matt T
Replied by Matt T on topic Longer leads for Snap On Modis Ultra
The quick and dirty solution is to get some 4mm banana couplers which'll allow you to connect a regular test lead to the end of your Snap-on lead. Or you can buy 4mm male x female extension leads. Neither of those options will give you shielding on the extension though.
5 years 8 months ago #46805 by Noah
Replied by Noah on topic Longer leads for Snap On Modis Ultra
All the channels share the same ground so as long as you have the black lead hooked up, you're good to go.
I have, in a pinch, made a set a of leads to test the fuel pump driver in the trunk of of a Lincoln with the Verus on the front seat.
At the time I was working at a junk yard, so it was easy to grab a set of RCA cables from a car stereo (they were already the length of a whole car) and just put banana lead ends on them.
5 years 8 months ago #46841 by Ferox
Replied by Ferox on topic Longer leads for Snap On Modis Ultra
Thanks that are some good tips. But what i don't understand, when they share ground why the green lead have the ground also?
5 years 8 months ago #46842 by Matt T
Ferox wrote: Thanks that are some good tips. But what i don't understand, when they share ground why the green lead have the ground also?
Green isn't the ground lead it's just one of the four color coded channel leads. Has a ground for shielding same as the other three.
5 years 8 months ago - 5 years 8 months ago #46858 by Noah
That's the "feel good" ground B)
As long as you have the scope grounded, you don't exactly need to use the black lead that's hanging off the green one. You could plug any single test lead into CH 2.
Last edit: 5 years 8 months ago by Noah.
5 years 8 months ago - 5 years 8 months ago #46859 by Noah
Like Matt mentioned, it's for shielding.
5 years 8 months ago #46964 by Ferox
Ah ok, i understand it now. Thanks for the help guys!
5 years 8 months ago #46972 by Dtnel
Replied by Dtnel on topic Longer leads for Snap On Modis Ultra
A little late for my answer but I'd recommend calling Jorge at AES wave and speak with him especially if you have other items you're considering getting as maybe they can work a "bundle" deal with you.
5 years 8 months ago #47132 by Ferox
Yes that's also a good idea. It's mostly the taxes that makes it expensive.
5 years 8 months ago #47134 by Matt T
Steve at Simply Diag mentioned getting a longer lead from Warwick Test Supplies in a video yesterday. They're in the UK so might work out cheaper??
5 years 8 months ago #47217 by Ferox
Matt T wrote: Steve at Simply Diag mentioned getting a longer lead from Warwick Test Supplies in a video yesterday. They're in the UK so might work out cheaper??
Great tip Matt! I'm gonna order them.
