low amp probe and multimeter readings
- Mechanic 350
- Thank you received: 15
5 years 9 months ago #46164
by Mechanic 350
low amp probe and multimeter readings was created by Mechanic 350
I hooked up my low amp probe to the negative side of the battery to see amperage and I saw a reading of 0.14v on my voltmeter, while on a 20A scale. What does that mean? don't know how to convert it. And i already saw some videos with paul but not clear enough. thanks.
- Matt T
- Thank you received: 276
5 years 9 months ago #46165
by Matt T
Replied by Matt T on topic low amp probe and multimeter readings
A millivolt is 1 thousandth of a volt. So multiply your 0.14 V by 1,000 to convert it to millivolts. 0.14 V is 140 mV.
Your clamp probably has millivolts per amp for each range marked on it. If it isn't you'll have to look those numbers up in the manual. Divide your mV reading by the mV/A to calculate the amps. If your clamp is 10 mV/A that 140 mV reading would be 14 A.
5 years 9 months ago #46166
Replied by Tyler on topic low amp probe and multimeter readings
Agree with Matt T. 14A would be a pretty normal charging rate for an idling engine without loads on.
The following user(s) said Thank You: Mechanic 350
- Mechanic 350
5 years 9 months ago #46177
by Mechanic 350
Replied by Mechanic 350 on topic low amp probe and multimeter readings
Matt, I have the snap on low amp probe. I have 20A and 40A scales on my probe. So the setting I had was set to 20A= 100mv/A. So divide my 140mv by 100?
- Mechanic 350
5 years 9 months ago #46178
by Mechanic 350
- Mechanic 350
5 years 9 months ago #46179
by Mechanic 350
So i divided my 140mv by 20A or 100mv/A?
- Matt T
5 years 9 months ago #46180
by Matt T
Correct. 140/100=1.4A.
Mechanic 350 wrote: Matt, I have the snap on low amp probe. I have 20A and 40A scales on my probe. So the setting I had was set to 20A= 100mv/A. So divide my 140mv by 100?
