Monitoring negative pressure in a crankcase could avoid a "leak down test"?
- Smeter12
- Thank you received: 4
5 years 9 months ago #46163
by Smeter12
Monitoring negative pressure in a crankcase could avoid a "leak down test"? was created by Smeter12
Hey,
Now I know measuring negative pressure of a crankcase can help one determine the condition of the piston rings. With that in mind, I have 2 questions:
1) the negative pressure in the crankcase is achieved when the piston is on its compression or exhaust stroke?
2) monitoring negative pressure in the crankcase is a pretty good way to avoid the labor time to complete a "leak down test"?
As always, thoughts appreciated and thanks in advance.
- Hardtopdr2
- Thank you received: 150
5 years 9 months ago #46447
by Hardtopdr2
Replied by Hardtopdr2 on topic Monitoring negative pressure in a crankcase could avoid a "leak down test"?
Negative pressure is achieved by the pcv valve and manifold vacuum.
The monitoring of negative pressure in crank case does not eliminate the need to do a leakdown test as it is 1/4 of the places leaks can go. I.E. crankcase, exhaust system, intake and out the coolant system are the 4 possibilities. The leak down test will eliminate 3 out of 4 possibilities leaving coolant system which can be tested via a pulse sensor, chem test (to an extent), pressure test of coolant system, rubber glove on coolant cap, evaluation of the oil in oil pan and coolant leaks around cylinder heads.
5 years 8 months ago #46559
Replied by Andy.MacFadyen on topic Monitoring negative pressure in a crankcase could avoid a "leak down test"?
One thing to keep in mind is that worn or broken oil control rings cause high oil consumption without any major effect on compression pressure.
