Capabilities of outdated scan tool software
- mcqman1
5 years 10 months ago #45635
by mcqman1
Capabilities of outdated scan tool software was created by mcqman1
When it comes to older software on these high end scan tools, will there come a point where the car is unable to communicate? I guess what I'm asking is if an older, but still capable scanner, like the OG Verus, is a smart buy with no more support? It's not uncommon for these to drop below $1000 on eBay. What is affected by out of date software? The whole car? Some functions/options missing? No comm? I'm sure the scope will continue to work fine, but please correct me if I'm wrong. I'm not concerned about older Windows/Android OSs, just the scanner software that's loaded on it.
Thanks,
David
Thanks,
David
5 years 10 months ago - 5 years 10 months ago #45649
Replied by Andy.MacFadyen on topic Capabilities of outdated scan tool software
The software has to be updated to work with later model cars and modules. If the software isn't updated it will continue to work on older vehicles.
I might add I use one piece of software that I have to set the computer date back to 2003 to use.
Last edit: 5 years 10 months ago by Andy.MacFadyen.
5 years 10 months ago #45650
Replied by Tyler on topic Capabilities of outdated scan tool software
An OG Verus will still keep working on YMM's its software supports, for as long as you can keep the unit itself alive.
So, if you had a Verus updated to 15.X, you'd be able to communicate with vehicles up to 2014 and into '15. If you don't work on stuff newer than 2014, then it's not a problem.
The updates add YMM's, of course. But, they also retroactively add functionality and refinements to older vehicles. Some changes are pretty minor, some are huge. Thus, even if you may not be working on the newest vehicles, it can still be beneficial to have the latest software. Or, the latest available for the tool, anyway.
- mcqman1
5 years 10 months ago #45696
by mcqman1
Replied by mcqman1 on topic Capabilities of outdated scan tool software
Thanks all for the info. What about basic OBD2 functionality? If I try and load a scanner that has software loaded only for YMMs up to say 2015 on a 2020 vehicle, will it be a no comm? I have a hard time justifying any buying tool that becomes a paper weight after a few years. I don't do this stuff for a living.
5 years 9 months ago #45705
Replied by Noah on topic Capabilities of outdated scan tool software
It will still work under global OBD for the cars outside of the year range the software is for.
So even if you only have version 15.x, it will read and clear codes and show live data for any OBD 2 vehicle up to present, so you wouldn't be left completely in the dark. You just won't have the extensive manufacturer specific data, bidirectional controls, or access to modules other than the engine control module in global OBD mode.
