Interesting fuel pump failure
Scoping the fuel pump current with a fuel pump relay jumper installed so I can field the pump on my own. This is what I find:
I'm pretty sure the pump motor is seizing up. :huh: It's not like the brushes are worn or the motor segments are open - there's current flow every time I close the relay. I sold a pump assembly and time to investigate the tank for water/debris/sugar/whatever.
Anything I'm missing?
- Matt T
- Thank you received: 276
Matt T wrote: It is a bit weird that once the pump gets moving it's current draw is normal.
Agreed. Once it gets moving, it's happy-ish. It even produces some fuel pressure! :silly:
Any chance of zooming in to see individual commutator humps? I'm wondering if there is a "sticky spot" that has, slightly, higher current on a single, repeating commutator.
You know, I actually wondered the same thing? Which is why I went back to these captures in the first place. Turns out, the Triton didn't save the capture correctly. Again.
This was my screenshot:
And this is the exact same capture when viewed in ShopStream Connect:
All the current values are off by one decimal point. :blink: So all of the detail in the pump waveform is gone. If it helps, this is about the most coherent detail I could get out of it:
- Matt T
Matt T wrote: Apparently there is a new version of Shopstream. If you haven't already upgraded that might fix the problem viewing Triton files. I'm installing it right now if you want to post the VSM and I'll try viewing it.
Sure, happy to!
Unfortunately, I already have that version.
Interestingly, the captures still have the correct scaling when viewed on the Triton itself. :huh:
- Matt T
Tried opening the .lsm file in 19.? and it was scaled wrong same as in 20.4. But at least the zoom worked
Matt T wrote: That 20.4 SSC software is junk.
Ain't that the truth. :lol:
The zoom didn't work, and when I clicked Help>User Forum it launched interlink exploder :blink:
You know, I never even thought to try that!
