Easy Circuit Testing?
  • AJeep18
  • AJeep18's Avatar Topic Author
5 years 10 months ago #45265 by AJeep18
Easy Circuit Testing? was created by AJeep18
Just trying to make sure that I am understanding correctly, so if it am figuring out a problem with a circuit such as a thermistor, trying to figure out if the circuit wiring or the sensor is the problem, is it ok to ground the signal wire with a test light, or jump it with the ground wire? Are there cases when this is not ok? I know you would not want to ground a 5v ref power wire; because that would drop the whole circuit right? But could I jump the 5v ref power with the sensor signal? I just don't want to smoke a computer :)
5 years 10 months ago #45268 by Tyler
Replied by Tyler on topic Easy Circuit Testing?
In the case of thermistors, you can pretty confidently ground the signal wire with no risk to the PCM. NTC thermistors are, by design, progressive shorts to ground.
I can't think of a situation that you wouldn't want to do this kind of testing? Not right now, anyway. :silly:
5 years 10 months ago - 5 years 10 months ago #45269 by Chad
Replied by Chad on topic Easy Circuit Testing?
AJeep18 wrote: is it ok to ground the signal wire with a test light, or jump it with the ground wire?
Yes. Thermistor Circuits have and internal resistor that protects them from shorting. The Sensor, itself, shorts the Bias voltage to ground, (or, power) at varying degrees of resistance, changing with temperature.
Not to my knowledge. Someone will chime in, if I am wrong.
Right. Do not do that.
Yes, you can do that but, remember that the thermistor signal circuit may have a 5 volt bias.
Last edit: 5 years 10 months ago by Chad.
5 years 10 months ago #45270 by Chad
Tyler wins, by a nose! :cheer:
  • AJeep18
5 years 10 months ago #45281 by AJeep18
Replied by AJeep18 on topic Easy Circuit Testing?
Ok thanks! I was just using a thermistor as an example because I have dealt with a couple lately. The same thing would apply to pressure sensors as well right? A three wire would have power ground and signal and one could jump the signal with one of the other two and check the circuit that way right?
5 years 10 months ago #45288 by Chad
AJeep18 wrote: The same thing would apply to pressure sensors as well right? A three wire would have power ground and signal and one could jump the signal with one of the other two and check the circuit that way right?
Yes. The scan data should go from one extreme, to the other.
