Scan tool
  • Chevyman
  • Chevyman's Avatar Topic Author
5 years 10 months ago #45177 by Chevyman
Scan tool was created by Chevyman
As a dyi yourselfer what would be a good scan tool to purchase. Not much money as just hobby for now. Would like to see what people are using.
5 years 10 months ago #45225 by Tutti57
Replied by Tutti57 on topic Re:Scan tool
If you don't need access to all of the vehicle modules or bidirectional controls, it's hard to beat a $10 bluetooth dongle for your phone found on amazon or ebay, with an inexpensive app like torque pro for $5. You can do quite a bit with a generic obd2 tool.
Autel and Launch make a good range of products for all different skill levels and applications at good price points, in my opinion.
Nissan Tech
5 years 10 months ago #45229 by J.D.
Replied by J.D. on topic Re:Scan tool
I recently purchased a Bosch 1350. I had been using AutoEnginuity's software [since about 2004-5], but it bacame useless when the laptop got old and died. I am only a DIY guy anymore. Took my "shingle" down years ago. Once in a while I'll still diagnose a problem for a friend. ...J.D.
5 years 10 months ago - 5 years 10 months ago #45239 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Scan tool
You can go a long way with a basic eBay ELM327 bluetooth dongle and the right app --- I strongly favour InCar Doc Pro Android App which is much more a diagnostic tool with better graphing than Torque.
For a hand held basic OBD scantool/code reader the lower cost end of the Autel or Launch ranges is always a safe buy, One of the problems when selecting any scantool is the model designations get very confusing and extra features.
With Launch the lower cost tools start with the CRP ranges , the X431 tools are pro and semi-pro. With Autel the more capable the tool the higher the model number.
With handheld scantools It is a minimum essential to buy one that gives you live data, also having graphing makes a big difference. You might want to look at the Autel AL519 or the or AL539 AL539B or AL619 or ML629.
OBD2 or EOBD or JOBD has limitations even more so on Euro and Asian manufacturers for example I had a fault light on in a older Land-Rover Freelander diesel that wouln't return or clear a code under standard OBD. It turned out to be a very simple fault but needed a scanntool that covered LR.
OBD/EOBD/JOBD is basic engine and transmission codes and data although so as you go up Autel and Launch you get extra functions such as SRS and ABS data (really pretty essential), TPMS and handbrake reset.
Last edit: 5 years 10 months ago by Andy.MacFadyen.
5 years 10 months ago #45240 by Tyler
Replied by Tyler on topic Scan tool
The answer is gonna depend on your personal fleet size/makeup, and how much work you do for others. For me, the Autel MX808 is nearly impossible to beat for the price and functionality:
www.amazon.com/Autel-MaxiCheck-Diagnosti...ctions/dp/B07FKZJ86W
There are definitely cheaper options out there, but few will be as capable or work as well. It's easy to say you don't need to be able to talk to a RCDLR on a Chevy, until you do. ;)
