Testing a MAF sensor - Verus lapscope or Verus Guided component test meter
- Smeter12
- Thank you received: 4
5 years 10 months ago #45030
by Smeter12
Testing a MAF sensor - Verus lapscope or Verus Guided component test meter was created by Smeter12
Background info- trying to determine if a MAF sensor on a 1995 Jaguar XJS 4.0L engine is faulty based on scoping.
Attached, please find 2 pics:
- Pic 1 - I am in my "Guided Component Test > DC Voltage Test" and trying to determine the health of the MAF. As per Pic 1, you can see the MAF voltage is at about 1.5 V as the engine idles.
- Pic 2 - a glitch caught when monitoring the MAF signal (Channel 1 noted in yellow) and the IAT sensor voltage (Channel 2 noted in green).
Today's million dollar question
- does the "lapscope" feature on the Verus have a higher resolution and sampling rate then the "Graphing Multimeter > Volts DC" meter on the Verus? I never caught the glitch when in my guided component test portion of the scan tool, however, I caught a glitch when in the lapscope portion of the Verus.
Million answer would be?
a) Glitch never happened when scoping in "guided component testing" and did when in "lapscope'
b) "lapscope" is always a better choice when trying to find a voltage/glitch issue because it has a higher sampling rate.
As always - thoughts appreciated and thanks in advance.
5 years 10 months ago #45105
It does indeed have a higher resolution and sampling rate, and that's the double-edged nature of scope testing.
:lol:
It's my opinion that the glitch in your second picture is ignition noise. There's a TON of it in a running engine bay, and the scope test leads will readily pick it up. It's always there.
Your lab scope captures picked it up because of your scope settings - 1ms time base, .5v/div with Peak Detect enabled. No offense meant here, but at those settings, you'll see your neighbors dog farting. :silly: The 'glitch' is there, but it doesn't impact the performance of the MAF.
I guess this depends on how you look at it? Literally. :lol: The glitch was always there, it just depended on your scope settings. That's the problem with scopes - it's easy to go down a rabbit hole.
b) "lapscope" is always a better choice when trying to find a voltage/glitch issue because it has a higher sampling rate.[/quote]
This is also subjective, IMO. In general, I'll say that the Lab Scope option is better when you know what you're looking for.
Replied by Tyler on topic Testing a MAF sensor - Verus lapscope or Verus Guided component test meter
Smeter12 wrote: - does the "lapscope" feature on the Verus have a higher resolution and sampling rate then the "Graphing Multimeter > Volts DC" meter on the Verus?
Time to create page: 0.266 seconds
