Best procedure for relative compression test without clear flood mode
- Seanerz
Thanks!
- Alex Ace Auto
- Thank you received: 3
- juergen.scholl
- Active partschanger
- Thank you received: 462
My all time favorite on cars with a chip in the key fob is to wrap this part in aluminum foil or hold a magnet close to it while cranking. (This might need an realignment on some rolling code/infrared systems afterwards like Renault, Mercedes employ)
This procedure will allow in most cases to aquire a sync signal from ignition when pulling a fuse cuts injection and spark and it is quick and dirty.
It goes against every fiber of my being to disagree with Juergen, but I recently worked on a Chevy Impala that would run with the crank sensor disconnected.juergen.scholl wrote: Disconnecting the crank sensor will work on all engines, others may not star with the cam sensors disabled.
- juergen.scholl
I stand corrected and was wrong! Thank you for making this clear.
Some have a fall back mode that needs only the crank sensor to start as for example on LR Freelander 1
Some need only the cam sensor.
If there is a bump switch pulling or tripping that works
With Bosch common rail diesels disconnecting the cam sensor or fuel rail pressure sensors will do the job.
Another alternative is to leave the key out the ignition and activate the starter solenoid with a jumber lead or remote start push button. but make 100% sure the transmission is out of gear.
- Matt T
- Thank you received: 276
Andy.MacFadyen wrote: Another alternative is to leave the key out the ignition and activate the starter solenoid with a jumber lead or remote start push button. but make 100% sure the transmission is out of gear.
Downside of that technique is you probably won't be able to get a sync signal.
Really best way is to disable fuel but the best way to accomplish that varies by vehicle.
juergen.scholl wrote: My all time favorite on cars with a chip in the key fob is to wrap this part in aluminum foil or hold a magnet close to it while cranking. (This might need an realignment on some rolling code/infrared systems afterwards like Renault, Mercedes employ)
Ayyyyyyy I gotta try that.
