Home made in cylinder transducer
6 years 4 months ago - 6 years 4 months ago #41057 by juergen.scholl
Replied by juergen.scholl on topic Home made in cylinder transducer
You'll need an intake manifold pressure capture and, if possible, an exhaust capture as well... You might get an intake capture from the map, if present. A snap throttle capture would be helpful as well.
Cyl #4 got a massive leak, somewhere;compression towers are shifted. some valve events on #4 seem to take place later than on #3. Both cylinders can not evacuate the exhaust gas properly. The pressure build up in #4 both on the exhaust ramp as on the compression stroke does show a very rounded curve....
It looks to me that the exhaust is partially clogged, affecting both cylinders. Furthermore the #4 intake valve does not close properly.
I attached some pictures with rulers...
Last edit: 6 years 4 months ago by juergen.scholl.
6 years 4 months ago #41063 by Matt T
Replied by Matt T on topic Home made in cylinder transducer
Noah, could you confirm whether these traces are from cyls 2 & 3 or 3 & 4. I thought the trace labelled 4 was a typo because it didn't match everything else you'd written. If it is 3 and 4 that'd make Juergens exhaust back pressure explanation more likely than my guess.
6 years 4 months ago - 6 years 4 months ago #41064 by Noah
Replied by Noah on topic Home made in cylinder transducer
They are labeled incorrectly, that's my bad.
The cylinder with high compression is cylinder#2, the lower compression cylinder is #3.
I attempted to collect a capture from #4 but it won't run on one cylinder.
I get out early today so I'm going to try to make a sensor to put on the intake unless something else comes up.
Thanks for the feedback guys!
Last edit: 6 years 4 months ago by Noah.
6 years 3 months ago - 6 years 3 months ago #41091 by Noah
Thank you for taking the time to give an in depth look at my captures Juergen, and I apologize for not having them labeled correctly.
It's very helpful for me to have your insight.
I agree with your assessment of the exhaust not being able to leave the cylinder quickly.
The fact that it takes a long time for the exhaust to reach atmospheric coupled with the fact that both cylinders look similar in that regard makes me wonder if the DIY timing belt replacement could have installed another problem after he broke the car beating on it.
Do you think that the exhaust pressure displayed could be accounted for by incorrect cam timing, considering it is common to both cylinders, or is there something else in the capture that might indicate this is not the case?
Just so we're all on the same page this is a single over head camshaft design.
Using AC coupling puts atmosphere @ 0.03v. I am roughly at sea level.
The actual running compression of the known good Taurus was about 75psi according to my mechanical gauge.
Just to give an idea of the voltage to pressure scale.
Last edit: 6 years 3 months ago by Noah.
6 years 3 months ago #41092 by Noah
When I get back Monday I will rename the captures accordingly. I also have the .vsm files if anyone would like to view them in Shop stream.
6 years 3 months ago #41101 by juergen.scholl
Noah wrote: When I get back Monday I will rename the captures accordingly. I also have the .vsm files if anyone would like to view them in Shop stream.
Please upload the vsm files. Thank you.
6 years 3 months ago #41127 by Noah
I had a little time after work to play with the Accord and some pressure sensors.
I tried a GM fuel tank pressure sensor, but wasn't immediately impressed. I ended up with a GM MAP sensor, so its an absolute pressure sensor, high voltage is BARO, low voltage is vacuum.
The first capture is engine cranking closed throttle, relative compression & intake vacuum. There is no appreciable in cylinder waveform during cranking so ch1 was turned off for this capture.
Next up is a running capture featuring intake manifold vacuum, in cylinder compression on cylinder #3 and ignition sync #3
6 years 3 months ago #41129 by Noah
File Attachment:
File Name: AccordLowC...sion.zip
File Size:849 KB
Here are the unedited .vss files
6 years 3 months ago #41136 by juergen.scholl
Both cylinders # 2 and #3 lack compression. #3 shows no resistance at all to the starter motor while #2 seems to have a little bit of compression. Because of the massive leak I believe that the pressure peak of #3 dos not coincide with the actual TDC. The intake pull for cylinder #3 is completely absent but the valve does open and it does not leak into the intake manifold. The intake valve of #2 doesn't leak either into the intake manifold. The valve timing seems to be correct. ( With the engine running the exhaust valves of the bad cylinders seem to close 10 degrees later than the better ones but I think this is due to difference in rotational speed because of the deficient compression.
I'd love to see a a cranking exhaust pressure waveform, maybe you can take one?. Although the two bad cylinders are adjacent it does not look to me as if a blown headgasket causes one cylinder to evacuate into the other; in this case I'd expect both cylinders to be afffected in a more similar way....
You may want to try to AC- couple the MAP sensor in order to gain a higher resolution.
6 years 3 months ago #41142 by Noah
As always, thank you Juergen for sharing your knowledge :)
With the vacuum sensor AC coupled it behaves differently.
Instead of outputting a linear voltage, the waveform looks more like a differential sensor. If I have the opportunity after work to play some more I will attempt to gather some exhaust patterns.
Again, thank you for taking the time to look at my captures and share your knowledge.
This kind of testing is new to me, but I would very much like to understand it enough to start incorporating it into my routine.
6 years 3 months ago - 6 years 3 months ago #41149 by Noah
I'm still digesting your analysis Juergen. I'm just starting to learn how to apply the over lay software and calculate degrees of rotation to valve events. The ones that you applied to the In cylinder captures are very helpful.
Nice job picking out the firing order on the relative compression & vacuum wave form.
I really should have used an ignition sync.
I honestly expected to see a greater compression hump from cylinder #2 based on the in cylinder pattern from #2.
It looked pretty regular while running compared to the couple of known good captures I have from the Taurus and my Ridgeline. Could the use AC coupling be skewing the captures?
Of course running compression is lower than cranking, so that must be the reason for it but for me it was unexpected. (I was secretly beginning to doubt the previous techs cranking compression test results after seeing the in cylinder for the first time)
Another thing that I was thinking about was the low compression on cylinder 3 coupled with the lack of an intake pull for the same cylinder. Is it possible that the intake valve does not open, resulting in no air to compress ultimately resulting in no compression? I know you said that cylinder 3 has a massive leak, is that based mostly on the low compression towers or is there another indicator that I am not seeing?
Once again, I greatly appreciate your help in understanding the results of these tests.
It will be fun to make a hypothesis and then prove or disprove it before the car is junked.
6 years 3 months ago #41367 by juergen.scholl
Hi Noah,
any news on that one? Did you dissect it?
6 years 3 months ago #41374 by Noah
I have not. I wanted to finish the 4 part Brandon Steckler class which has wrapped up now (cool to see members from the forum there :) ) to hopefully better grasp the anatomy of the waveform.
Did the .vss files work for you? I was looking at one last night that I took at higher rpm and it looked like the pressure on the exhaust stroke was equal to the pressure on the compression stroke after returning to near idle speed.
I think I've gotten as far as I can without actually observing the fault. Hopefully tomorrow afternoon I will have the time and ambition to pull it out of the junk yard and do a leak down test and maybe pull the head.
Thank you for your help and interest Juergen. You are a genuine asset to this community.
6 years 3 months ago - 6 years 3 months ago #41379 by Matt T
Noah wrote: Could the use AC coupling be skewing the captures?
It doesn't seem to be giving a consistent atmospheric pressure reference, which is making it impossible to tell whether the exhaust stroke is slowly rising to atmospheric or building positive pressure. You mentioned earlier that AC coupling puts atmospheric around 0V but the latest #3 in cylinder picture never drops to zero and appears to be peaking north of 0.2V at the end of the exhaust stroke?? I think it'd be worth getting a DC running compression before you tear into it.
I also agree with Juergen that exhaust back pressure would be good to have. There's probably something turbocharged in the yard you can harvest a suitable sensor from ;)
Last edit: 6 years 3 months ago by Matt T.
6 years 3 months ago - 6 years 3 months ago #41381 by Noah
I'm wondering if I can power it from the auxiliary port on the top of the Verus where the Snap On transducer would get its power and ground. Then maybe I could get a good calibration and use the PSI scales.
I'm pretty sure the Snap On transducer and the one I am using are both 500psi.
I think I have 2 secondary rpm pick-ups collecting dust, I may try to cannibalize one....
I definitely need to do more testing to be able to translate the voltage scales to actually pressure and vacuum.
I will continue post here as I experiment, thank you for your input. It is greatly appreciated!
6 years 3 months ago #41386 by Matt T
Google found this which has pin-outs in the pdf attached to the first post. One interesting thing is that the aux port 0V is floating relative to the 'scope ground. Makes me wonder if maybe the 'scope does something in transducer mode to filter out any voltage changes between aux 0V and ground. Might switch that channels ground over to 0V or something??
Also if the aux 0V floats there's a good chance the USBs will too. Something else to bear in mind if you're unable to get a consistent DC reading at atmospheric pressure. I wouldn't tie the 'scopes 0V to 'scope ground but powering the transducer with a wall wart and tying it's 0V to the 'scope ground shouldn't cause any problems. Or at least not any expensive ones :lol:
www.scannerdanner.com/forum/diagnostic-t...sure-transducer.html
6 years 3 months ago #41391 by Noah
I forgot all about that thread!
Thank you once again Matt, owe you a beer :)
I found the utility in Windows to test various functions of the scope, including the 5v power supply on the aux plug and was able to ID power and ground. I intend to re-pin the Snap-On rpm pick up too utilize it to power the transducer.
Mine isn't power all the time, so I don't know if it powers on when you select an appropriate test lead preset for a given channel or how it works yet.
I Also want to try a "wall wart" as you call it to see if it skews the 0 line compared to the USB ports on the Verus.
I downloaded the PDF and gave it a glance but I will give it a thorough read through this afternoon.
Once again, thank you very much!
6 years 3 months ago - 6 years 3 months ago #41520 by Noah
Paul, I can't seem to get this to work for me.
I repinned an rpm pick up for the Verus to supply power and ground to my transducer but the calibration fails every time and the pressure ends up skewed very negative.
I have a couple that output 0.5 volts at atmosphere and it still won't take.
Do you use yours on the pressure setting or volts?
Very nice build by the way. I need some kind of coupler to thread mine into a compression gauge hose.
6 years 3 months ago #41521 by Paul Marchant
Replied by Paul Marchant on topic Home made in cylinder transducer
Pressure mode on the Verus and on the Vantage Pro, and it works every time.
So, some faultfinding is in order.
With the back removed from the d-type, plugged in to the diagnostic tool, with the pressure sensor soldered on, what voltages do you see on the relevant pins (as per the crap picture in my documentation)?
The Verus seems to expect a transducer that outputs 0.5 to 4.5v, with 0.5v for zero PSIG. When it does the 'calibration' thing, it's assuming that the transducer is electrically connected, but with zero pressure on it. This voltage is then deemed to be zero PSI by the Verus / Vantage Pro and 4.5v is full-scale (i.e. 500PSIG if you're in 500PSI sensor mode).
6 years 3 months ago #41522 by Matt T
For adapting the transducers to a gauge hose do you know what thread diameter and pitch they are? And whether they're taper seal like a pipe thread or use a gasket or o ring?
Time to create page: 0.445 seconds
