No pulse sensor, no problem, scope the MAP sensor
  • John Curtis
  • John Curtis's Avatar Topic Author
6 years 4 months ago #40578 by John Curtis
So I decided to experiment and scoped a MAP sensor during a crank event to see if I could use it in place of a pressure pulse sensor. In short, it works well enough to see valve events.
Just thought I’d share with you guys.
Would this forum benefit from an “unconventional testing” sub forum?
6 years 4 months ago #40597 by Cheryl
Got a screenshot? What we’re your settings on your scope?
6 years 4 months ago #40602 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic No pulse sensor, no problem, scope the MAP sensor
Bosch hotwire MAF will also intake pulses but how useful it could be is doubtful.
  • John Curtis
6 years 4 months ago #40603 by John Curtis
Replied by John Curtis on topic No pulse sensor, no problem, scope the MAP sensor
Started on a 5V setting, went to a 2V setting and still needed some zoom. No screenshots unfortunately but I plan on experimenting with it again at some point and I’ll save some captures. I was very surprised to see a perfectly usable waveform that showed valve events. Actually discussed this with others and some suggested to completely disconnect the sensor electrically and use an external 5v supply.
  • John Curtis
6 years 4 months ago #40605 by John Curtis
Andy.MacFadyen wrote: Bosch hotwire MAF will also intake pulses but how useful it could be is doubtful.
Still very interesting at least to me. However, the location of the sensor is an important factor. Before the throttle plate, then you’re not gonna get the entire picture. In comparison as to where if the sensor is after the throttle plate.
And... could those intake pulses from a MAF sensor be interpreted to determine if the throttle plate is closing properly or if it might be stuck open by debris or other obstructions? While maybe not practical, I’d be curious about what the differences in a waveform will produce.
6 years 4 months ago #40609 by juergen.scholl
Replied by juergen.scholl on topic No pulse sensor, no problem, scope the MAP sensor
John Curtis wrote: Started on a 5V setting, went to a 2V setting and still needed some zoom.
You might want to try ac-coupling.....
6 years 4 months ago #40615 by Andy.MacFadyen
The MAF I first noticed it on was on a turbo diesel so no throttle plate I could actually see the pulses at idle although the MAF was before the turbo with a whole load of junk, turbo, inter cooler, EGR between the MAF and the cylinders. At least on a diesel it could be a method for spotting a valve related issue,
