COP Power Balance Test
- rockp2
- Thank you received: 40
9 years 9 months ago #5257
by rockp2
COP Power Balance Test was created by rockp2
Insight please. I've done power balance tests on computer controlled COP secondary ignition systems simply by momentarily unplugging the harness connector from each coil to find the problem cylinder. However, I last week purchased "The Hands On Vehicle Testing Reference" from AES Wave. In the book the author states that while it is ok to unplug the connector with the engine running, he stresses to NEVER "replace this harness with the engine running as a resulting voltage surge could spike the computer." The author states that after removing each connector shut the engine off, then replace the connector, then restart the engine and go to the next connector to disconnect. Have I been doing this incorrectly and risked a voltage spike to the computer by unplugging each connector and reconnecting with the engine running?
- ScannerDanner
- Administrator
- Thank you received: 500
9 years 9 months ago #5258
by ScannerDanner
Don't be a parts changer!
Replied by ScannerDanner on topic COP Power Balance Test
Nope, you're fine. That is typical book type information. Think about the almost 400v primary spike that is occurring in these coils. How does unplugging it cause more of a spike than that?!
The following user(s) said Thank You: rockp2
- rockp2
9 years 9 months ago #5259
by rockp2
Replied by rockp2 on topic COP Power Balance Test
Thanks for the response. I kind of suspected as much. Kind of like the old "Never use a test light on a computer circuit."
9 years 9 months ago #5268
Replied by Tyler on topic COP Power Balance Test
Yeah, that stuff still gets perpetuated among technicians, even today.
