Graphing RPM
- jarayner23
6 years 7 months ago #38444
by jarayner23
Graphing RPM was created by jarayner23
- John Curtis
- Thank you received: 111
6 years 7 months ago #38445
by John Curtis
Replied by John Curtis on topic Graphing RPM
PIP is crank signal. Something specific to Ford is that during crank the CEL will go off showing it’s getting RPM signal.
- jarayner23
6 years 7 months ago #38473
by jarayner23
Replied by jarayner23 on topic Graphing RPM
Okay sweet. found it and got a waveform. whats the easiest way to convert this to an rpm and graph it?
- jarayner23
6 years 7 months ago #38474
by jarayner23
- jarayner23
6 years 7 months ago #38475
by jarayner23
also a question on the above waveform would i say the 5 wider waveforms would be ther reluctor then what is the narrower waveform represent?
- John Curtis
6 years 7 months ago #38514
by John Curtis
Repetition = Revolution
You can use rulers from the bottom left and drag them to where you want to measure. Should display rpm between
Or click measurements, pick channel, change measurement type to frequency, and choose between rulers... and place your rulers. Frequency is pretty much the same as RPMs. Its a measurement per second and RPM is per minute
