Calculated Load vs. Absolute Load
9 years 7 months ago #7080 by Noah
Replied by Noah on topic Calculated Load vs. Absolute Load
Decided to play a bit more with Absolute Load, this time on an '08 Escape. 3.0L engine
New guinea pig is working out good I take it :whistle:
  • Tyler's Avatar Topic Author
9 years 7 months ago #7082 by Tyler
Replied by Tyler on topic Calculated Load vs. Absolute Load
Whaaaaaaat? I never perform testing on my personal vehicles! :whistle: ;)
9 years 7 months ago #7106 by gav09
Replied by gav09 on topic Calculated Load vs. Absolute Load
Sorry about the delay but here is the screenshot. I don't remember what vehicle it was but 92.434% on the calculator and 92% on the scan data.
9 years 7 months ago #7109 by Tyler
gav09 wrote: Sorry about the delay but here is the screenshot. I don't remember what vehicle it was but 92.434% on the calculator and 92% on the scan data.
Sweet! :cheer: That's what I was looking at the other day on another GM, didn't have time to really play with it.
I wonder if they're actually taking the Absolute Load PID from Global and renaming it Volumetric Efficiency in Enhanced data? :huh:
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 7 months ago - 9 years 7 months ago #7118 by Dylan
Replied by Dylan on topic Calculated Load vs. Absolute Load
Thanks! Karma bump for you.
I'm also using Tech2 and I haven't noticed this PID... I'll keep it in mind that's for sure. Your VE calculator is from Windows store? Just asking cause we're talking about calculators since Tyler revealed that the one from OTC is crap and so we're on the hunt for a good one :lol:
Good question :S
Last edit: 9 years 7 months ago by Dylan.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 4 months ago #10152 by Dylan
COOL! Check this one out guys :woohoo:
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
9 years 4 months ago #10162 by ScannerDanner
Replied by ScannerDanner on topic Calculated Load vs. Absolute Load
Good timing huh? I seriously didn't know this was here. Thanks guys!
Don't be a parts changer!
9 years 4 months ago #10171 by Tyler
Sweet! I'll be watching that video later on tonight.
I also learned at Vision that Absolute Load is very useful for forced induction diagnostics, particularly on newer Ford EcoBoost engines. I'm told that a peak Absolute Load of 150-175% is typical on Ecoboost platforms. I ran into a '13 Edge with a turbocharger issue recently that became much more obvious once I started looking at Absolute Load.
This one had a wastegate problem that prevented maximum boost, and resulted in a DTC.
This shot is off a 'chipped' 3.5L F-150. Almost hit 200% Absolute Load. :ohmy:
9 years 4 months ago #10206 by matt.white
Replied by matt.white on topic Calculated Load vs. Absolute Load
Just watching Pauls video, there's huge discrepancies between the load data shown between the 3 vehicles. From memory the F150 peaked at 89%, his ute reached 99% but seem to be fairly related to what was being asked of the motor. The Lincoln however really seemed to jump around a lot and reach 100% when it didn't seem to be under any load. Just an observation.
Also, my understanding of this VE calculator is stripping back fuel delivery and spark timing and simply measuring the engine as an air pump. You guys agree that's a fair comparison?
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 4 months ago #10214 by Dylan
matt.white wrote: Also, my understanding of this VE calculator is stripping back fuel delivery and spark timing and simply measuring the engine as an air pump. You guys agree that's a fair comparison?
I agree Matt. Volumetric efficiency is basically an indication how well an engine breathes. I don't consider it as a magic calculation that will solve our problems in the blink of an eye ;) BUT I'm pretty curious what Paul's going to do with this.
9 years 4 months ago - 9 years 4 months ago #10219 by Tyler
matt.white wrote: Just watching Pauls video, there's huge discrepancies between the load data shown between the 3 vehicles. From memory the F150 peaked at 89%, his ute reached 99% but seem to be fairly related to what was being asked of the motor. The Lincoln however really seemed to jump around a lot and reach 100% when it didn't seem to be under any load. Just an observation.
Good observation, sir! I've seen maximum Load vary between makes on known good vehicles, possibly due to variations in inputs? Most Ford vehicles won't go to 95-100% Load, but GM's usually will. Not sure what was up with the Lincoln... I'd know more if I knew which engine it had in it. Many newer vehicles will clear 100% Load due to VVT and forced induction.
Sorta? The trouble is that the VE calculation is based largely on the MAF reading, which can misreport (dirty, skewed, whatever). The VE test can't make a distinction between a pumping problem and a measurement problem. But, neither can Load. :silly:
Last edit: 9 years 4 months ago by Tyler.
9 years 4 months ago #10247 by Pontisteve
Replied by Pontisteve on topic Volumetric Efficiency calculations
Hi guys,
When you're using these VE calculators, there's something you should keep in mind. Peak torque happens at an RPM well below where peak HP occurs. For example, on an LS V8 Chevy engine, peak torque typically occurs around 4500 RPM, while peak HP might occur at 6500 RPM.
Every motor has a sweet spot where it's the most efficient air pump. As you climb towards this peak efficiency point, airflow goes up. Above peak efficiency, airflow actual begins to go down. The Torque curve of the engine shows this.
When you measure maximum engine airflow, that airflow will occur right around peak torque. When you measure this peak mass airflow, you should also record the engine RPM at that same point, and use it in the volumetric efficiency calculators.
9 years 4 months ago - 9 years 4 months ago #10248 by Pontisteve
If you would like to read more about Volumetric Efficiency testing, I recently wrote an article on it here:
www.facebook.com/DragRadialPerformance/posts/1365727770187096
I also made an Excel spreadsheet that calculates VE for you, which is available for free if you ask. In version 1.00, I added barometric pressure compensation. I may add air temp compensation in the near future. Currently, the program assumes standard temperature (59F).
Last edit: 9 years 4 months ago by Pontisteve.
The following user(s) said Thank You: Noah, Dylan, Tyler, Andy.MacFadyen
8 years 2 months ago #22407 by Flatrater
Replied by Flatrater on topic Calculated Load vs. Absolute Load
Hi Tyler
It looks like you are using the OTC calculator. It is not just broken, but it does not include BARO.
Here is a side by side comparison of one of your values. I added the baro from your capture on ScanShare
The ScanShare calculator code came from the Flatrater site.
8 years 2 months ago #22408 by Flatrater
" The VE test can't make a distinction between a pumping problem and a measurement problem. But, neither can Load."
If I'm understanding you correctly here, I would have to disagree.
If you assume...
WOT is either enrichment mode or CL
An O2 will switch high > stoich
For a skewed MAF to affect VE to any useful level, it will have to have a significant error
Then I think the problem is solved. I have been using and teaching this with examples for a long time.
8 years 2 months ago #22410 by Flatrater
"Conclusion: Absolute Load is kinda useless."
Per the J1979 definition, it is a "normalized" value.
Normalization of a data set I believe brings a good bit of value, but it does take some explaining.
I have a long term project on just this topic and it will likely end up being part of a new class.
I don't really care for generic data as it is so slow, so I've always used whatever definition of engine load the OE side of the scan tool uses and use other pids to give it context. The reason for the project is that I have to address this stuff industry wide, not just for myself.
I think I saw that you posted numerous GM examples. I have found GM to use at least 4 different engine load definitions, all with the same pid name. Other OEs seem to be a little less haphazard :-)
8 years 2 months ago #22411 by Flatrater
Ah snap...
Sorry Tyler, I didn't realize I hadn't read to the end of the thread :-)
8 years 2 months ago #22421 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Calculated Load vs. Absolute Load
An less techie name for volumetric efficiency would be cylinder filling effectiveness, how much "weight" of fresh air is actually getting in to refill the cylinder.
8 years 2 months ago #22428 by Tyler
Flatrater wrote: Ah snap...
:lol: No worries! As you can tell, I've been fumbling around with Load PIDs for awhile now. If I'm not drawing the right conclusions, I'm happy to hear about it.
Very interested. :ohmy: How do I get on a mailing list to get notified about this?
Would love to hear more about this.
8 years 2 months ago #22432 by Tyler
Flatrater wrote: " The VE test can't make a distinction between a pumping problem and a measurement problem. But, neither can Load."
Not trying to be argumentative, but would you mind checking my understanding? I had a Lexus that I believe was a good example of a measurement error causing a low VE calculation.
'99 ES 300, 3.0L, dirty MAF numbers:
And after cleaning:
In this situation, both Load and VE showed low values. With the VE test alone, I'm not sure how a distinction could be made between a measurement or breathing problem. Not unless the upstream sensors are considered. Or, was that your point? :silly:
Time to create page: 0.436 seconds
