Honda shift solenoid pintle hump
  • benphillipstn
  • benphillipstn's Avatar Topic Author
6 years 10 months ago #35745 by benphillipstn
Honda shift solenoid pintle hump was created by benphillipstn
Should all shift solenoids have a pintle hump when turning on and when turning off?
I am checking the shift solenoids on a 2002 crv and I don't see a pintle hump when any of the shift solenoids turn on. But I see a good pintle hump when the shift solenoids turn off.
The vehicle shifts fine except on the 3 - 2 downshift. There is a delay before 2nd gear engages.
6 years 10 months ago #35753 by Chad
Replied by Chad on topic Honda shift solenoid pintle hump
Are you looking at the Current waveform?
  • benphillipstn
6 years 10 months ago #35762 by benphillipstn
Replied by benphillipstn on topic Honda shift solenoid pintle hump
Yes. I will get a screen shot today. I should not have said all shift solenoids. I've only checked shift solenoid b and c. Neither one had a pintle hump when turning on. Solenoid C had a hump when turning off. I have not checked B turning off.
  • benphillipstn
6 years 10 months ago #35771 by benphillipstn
Here are some screen shots.
Shift solenoid C turning on:
Shift solenoid C turning off:
Shift solenoid B turning on:
Shift solenoid B turning off:
These are the only shift solenoids I've looked at. I thought there should be a pintle hump when they turn on and when they turn off. But I guess this is not always the case.
6 years 10 months ago - 6 years 10 months ago #35775 by Chad
Are those all CURRENT waveforms? Pintle closing is, generally, viewed in a VOLTAGE waveform, taken from the control side of the circuit.
Here is a video of ScannerDanner explaining injector waveforms. The principle is exactly the same for solenoids, although it is harder to see the pintle/poppet movement. This video shows how circuit design can affect the waveform.
ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19700000062.pdf
Last edit: 6 years 10 months ago by Chad.
The following user(s) said Thank You: benphillipstn
  • benphillipstn
6 years 10 months ago #35781 by benphillipstn
I haven't looked at the voltage waveform.
I found this:
www.atraonline.com/gears/2006/2006-09/2006_09_22.pdf
It shows two current waveforms of a 5r55e shift solenoid. It has a pintle hump when it turns on and when it turns off.
I thought there might be a reason some shift solenoids don't have the energizing pintle hump.
