Snap on obd1 adapters
- Jostr
6 years 11 months ago #35031
by Jostr
Snap on obd1 adapters was created by Jostr
Hi everybody,
I have a snap on verus edge with the obd1 adapters does anyone have an application guide for them. I'm about to use it for a check engine light on a 1995 ford ranger. My kit has a ford 4 and a ford 1b. I have never used them before and I'm guessing I need to use the ford 4 for my application. Do they require seperate power and grounds ?
Thanks for any info
Josh
Thanks for any info
Josh
6 years 11 months ago - 6 years 11 months ago #35032
Replied by Chad on topic Snap on obd1 adapters
The Verus will tell you which connector to use when you enter Year, Make, and Model. I don't think you will need an additional power source on this vehicle, but If the connector has a port for external power, be prepared to use it.
You will need Adapter DA-5.
www.snapon.com/Diagnostics/US/KB/DA-5-Adapter-Cable.htm
Last edit: 6 years 11 months ago by Chad.
- Jostr
6 years 11 months ago #35034
by Jostr
Replied by Jostr on topic Snap on obd1 adapters
Thanks Chad, I wasnt sure thank you for the help.
- Jostr
6 years 11 months ago #35070
by Jostr
Update, after the truck came in and I had a chance to look at it, the truck had an obd2 port I guess being a 06/95 build date they were ramping up for obd2
Thanks again
Thanks again
Time to create page: 0.259 seconds
