Coil current ramp and coil voltage
- DIYGUY
7 years 1 week ago - 7 years 1 week ago #34620
by DIYGUY
Coil current ramp and coil voltage was created by DIYGUY
I have watched a number of scannerdanner's videos. The one that has interested me recently has been about misfires, and using the current ramp of a ignition coil to determine what cylinder is the issue.
I had done some work to my car recently, which is a 99 chevy metro. It has a 3 cylinder engine in it. Afterwards, I had time to get my scope out and try some stuff out. I hooked up the amp clamp to the coil primary wiring. This is the waveform i got with the engine runing correctly.
www.flickr.com/gp/152203134@N05/M965Y4
I then put a spare used spark plug in the # 1 cylinder, but the electrode had no gap. I smashed it flat to similate a shorted plug wire.
I had expected the currecnt ramp to change and have a straight up line at the begining of the ramp, but it looked exactly the same as the normal one.
I thought about it for a little while then I realized my engine has a distributor, cap and rotor. So it still has to jump a air gap inside the distributor even if the plug no longer has a gap.
With my engine configuration, I will never see a straight up line at the beginning of current ramp will I, unless the coil secondary is shorted?
Last edit: 7 years 1 week ago by DIYGUY.
7 years 6 days ago #34626
Replied by Noah on topic Coil current ramp and coil voltage
Good question! A straight line in the current ramp would indicate a shorted primary winding, not a secondary problem. That's why your current ramp remained unchanged.
- DIYGUY
7 years 6 days ago #34628
by DIYGUY
Replied by DIYGUY on topic Coil current ramp and coil voltage
I will have to go back and check some of the videos then, I thought for sure he said it was a secondary ignition issue.
Thanks for the response.
- DIYGUY
7 years 6 days ago - 7 years 6 days ago #34630
by DIYGUY
Here is one of the videos were he saya shorted secondary. Near the 5:30 mark.
Last edit: 7 years 6 days ago by DIYGUY.
- DIYGUY
7 years 6 days ago - 7 years 6 days ago #34631
by DIYGUY
This video explains why I didn't see any difference in my spark waveform (i didn't post a picutre of it), when I had the spark plug gapsmashed flat. I have a distributor, with a cap and rotor. I should of snapped the throttle to see if there was a increase in KV voltage.
- Donut
- Thank you received: 11
7 years 5 days ago #34648
by Donut
"Don't ever say 'easy' until the check clears."
Replied by Donut on topic Coil current ramp and coil voltage
You wouldn't see a plug with a gap set to 0 on the primary side with an amp clamp since current is not flowing in the secondary circuit in that waveform you showed in the first post. As far as I know, which may be incorrect, a short in the secondary coil windings will have that straight line jump instead of coil oscillations, but I have forgotten whether that's just the behavior of the magnetic field with a short or due to the secondary and primary being connected.
You need to watch the voltage to see what the spark is doing, which means a capacitive clamp around the spark plug wire or coil wire going into the distributor. In which case you would see a high Kv with a sharp downward ramp where the firing line would be since all that voltage is going straight to ground
- DIYGUY
6 years 11 months ago #34750
by DIYGUY
Thank you for the response.
I believe your right, I will need to check the voltage going to the spark plug with a inductive clamp. There should be close to no burn line after the high kv line on the waveform.
I get a chance I will have to try that again.
