Testing Idle Control Valve stepper motor
  • spit64
  • spit64's Avatar Topic Author
9 years 10 months ago #4485 by spit64
When testing a 2 wire stepper motor ICV with a scope are you back probing both wires with one channel or both wire on one channel each, one wire on ch1 and second wire on ch2 with engine ground on both channels.
9 years 10 months ago - 9 years 10 months ago #4493 by Noah
Replied by Noah on topic Testing Idle Control Valve stepper motor
Hey there,
Good question. A two wire IAC motor is going to be PWM (pulse width modulated) or duty cycle controlled. You would have the ground lead on the battery, and ch1 lead to the control wire of the IAC.
I hope I haven't misinterpreted what you mean by ICV??
Here's a free ScannerDanner Premium classroom lecture on the subject.
The link should jump you right to the part about testing 2 wire IAC valves, but the whole video is full of good information if you've got time to watch the whole thing.
Last edit: 9 years 10 months ago by Noah.
The following user(s) said Thank You: spit64, aboudi.naddaf
  • spit64
9 years 10 months ago #4505 by spit64
Replied by spit64 on topic Testing Idle Control Valve stepper motor
Thanks for video link I missed it completly
9 years 10 months ago #4507 by Noah
You're welcome
9 years 8 months ago #6083 by Ash03
Replied by Ash03 on topic Testing Idle Control Valve stepper motor
Sorry for hijacking your thread, but, is there any way to test an idle air control stepper motor with a dvom? I suspect that I am having an issue with it on a car that I am working on. Its an 8 pin throttlebody that has the idle control motor built into the tps which is built into the throttlebody.
9 years 8 months ago #6106 by Noah
Ash03 wrote: Sorry for hijacking your thread, but, is there any way to test an idle air control stepper motor with a dvom? I suspect that I am having an issue with it on a car that I am working on. Its an 8 pin throttlebody that has the idle control motor built into the tps which is built into the throttlebody.
Hi Ash,
Why don't you start a new thread in the "Post your repair questions here" section?
You can fill us in with the year, make and model of the car and whatever symptoms you're experiencing, and more people will be able to provide more specific help.
9 years 8 months ago #6107 by Noah
Hi Ash,
OOPS! Looks like you've already done that! :blush:
9 years 8 months ago #6137 by Ash03
Lol yes i did Noah.. Im kind of desperate here i need to deliver in one day and I still havn't sorted out the issue
Time to create page: 0.332 seconds
