Nissan no start
- Caritech
- Thank you received: 10
Using a soldering gun I tried to get a response from the pcm (fire coils etc) but nothing. Took the 2 wire CKP off and repeated unplugged with volt meter attached in AC and it worked. Decided to go at the brain and found water intrusion in the harness but not the ecm.
At the ecm, on a crank using uscope, one wire was 12v all the time and the other showed a signal. I snipped the hot wire on both the ecm and sensor and jumped a fresh wire. Boom! Car started, now it has a misfire but that's for another day.
So, you gotta figure that hot wire is shorted to 12V in the harness somewhere, right?
- Caritech
Tyler wrote: Nice find with the 12V on the CKP wire! This might be Captain Obvious, but how did you use the soldering gun for a bypass test? :huh:
The soldering gun produces a magnetic field and the sensor starts producing a signal causing coil,injector and fuel pump trip on with KOEO.
Yup heading back to find the short. Note I was working on this car after 10 @ night initially.
- Dylan
- Belgium, Europe
- Thank you received: 327
:blink: :woohoo: Nice.... love this kind of info
Also another one on target for the uScope --- it might not be Pico but a very handy little tool.
- Caritech
