Another great case study
- Richey.brown
- Thank you received: 6
10 years 3 months ago - 10 years 3 months ago #338
by Richey.brown
Another great case study was created by Richey.brown
Hi I was presented with a Skoda Octavia 2010 diesel with P0237. Another garage had fitted a boost pressure sensor. So I checked the plausibility with a scantool and everything looked good. Took it for a road test and realised every time I took a rIght hand turn the boost pressure would drop below atmospheric. So I hook up the scope, 1 channel on the 5 volt ref and the other on the signal, low and behold the 5 volt ref would drop out when turning right. So I set about doing the "riggle" test and this is what I found!
Last edit: 10 years 3 months ago by Richey.brown.
- Dylan
- Belgium, Europe
- Thank you received: 327
10 years 3 months ago #344
by Dylan
Replied by Dylan on topic Another greason case study
Hey Richey! Great job. Thanks for sharing this and adding a video is awesome.
10 years 3 months ago #361
Replied by Tyler on topic Another greason case study
Nice find, sir! Had someone been into the wiring for that sensor before? Saw a butt connector on that yellow wire, wonder if something went wrong previously.
- Richey.brown
10 years 3 months ago - 10 years 3 months ago #364
by Richey.brown
Replied by Richey.brown on topic Another great case study
Hi yes someone had definitely been on the connector before and definitely on the yellow wire. But the yellow wire was nothing to do with the circuit I had a problem with. Well spotted though. The yellow wire was missing the weather pack but wasn't suffering from any fault. I did dribble some liquid electric tape into the back of it to hopefully prevent further corrosion.
- matt.white
- Thank you received: 29
10 years 3 months ago #372
by matt.white
Replied by matt.white on topic Another great case study
Well done Richey. Great job.
- JoesAutoElectric
10 years 2 months ago #1042
by JoesAutoElectric
"The man who says it cannot be done should not interrupt the man doing it."
Replied by JoesAutoElectric on topic Another great case study
Awesome find and great use of the scope!
