i just bought a used verus eems323 first gen and have a few questions
  • overdrive138
  • overdrive138's Avatar Topic Author
7 years 7 months ago #28041 by overdrive138
when i click multimeter/scope tab and pick dual graphing voltage or voltage should it make a noise ? I'm also getting readings of 0.03 v with nothing connected on two channels
  • overdrive138
7 years 7 months ago #28042 by overdrive138
can this verus still be updated?
  • overdrive138
7 years 7 months ago #28045 by overdrive138
the noise heard is a zapping type noise
7 years 7 months ago #28053 by Tyler
overdrive138 wrote: when i click multimeter/scope tab and pick dual graphing voltage or voltage should it make a noise ? I'm also getting readings of 0.03 v with nothing connected on two channels
The noise is entirely normal. :) Typical across the whole Snappy lineup.
That 'ghost voltage' of .03V is also pretty typical.
As far as I know? :silly: I haven't heard that they're dropping support yet.
7 years 7 months ago #28057 by Matts Auto
First gen verus is only updatable to i think 17.4 not 100% on that but you can call snap on customer support for verification
7 years 7 months ago #28063 by Noah
I run a first gen Verus just for the scope and she's getting a little tempermental in her old age.
I find that when shutting down the tool, putting it in hibernation mode saves a tremendous amount of boot up time. I also always leave it plugged in until I need to do a test, then it gets plugged right back in.
  • overdrive138
7 years 7 months ago #28073 by overdrive138
thanks for the reply guys. I was kinda worried about that zapping noise lol
7 years 6 months ago #28520 by sdata4
Were you able to get it updated to 17.4? cause I tried calling Snap-on and they basically said no more support!!
  • overdrive138
7 years 6 months ago #28701 by overdrive138
I wasnt able to get it updated but it is possible threw the usb flash drives that snap on use to sell. I Have part#s for different updates everything up to the pro can be used .
5 years 10 months ago #45480 by Techcompsolutions
You can download the updates but seems worthless without a newer license file. Kind of in the same bolt with an older eems325 anyone solved this I know this is an old old thread
