Voltage Drop
  • Tutti57
7 years 9 months ago #26235 by Tutti57
Voltage Drop was created by Tutti57
I understand that you would put one lead on battery + and the other lead on that wire at the load, load the circuit and want to see s less than .5v, or do all of that on the ground wire to check that side. Can you also go from battery - to load + side, load the circuit and look to see at least 11.5v then move your lead over from load + to load - and look to see .5v?
7 years 9 months ago #26251 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Voltage Drop
Yes but it needs care ---- yes because all the all the voltages in the circuit must add up to the supply voltage, the but comes in because putting any load on the battery pulls down the supply voltage.
