2017 GMC Sierra 5.3L -How to program new BCM to truck
- Mechanic 350
- Thank you received: 15
1 year 2 months ago #92140
by Mechanic 350
2017 GMC Sierra 5.3L -How to program new BCM to truck was created by Mechanic 350
I've never attempted this procedure before so I'm requesting a little guidance. For equipment, I have an Autel 908S PRO with the Jbox 2534. I have created an account with ac delco dts for software access. Will my scanner setup be enough to program a new bcm for this truck? Can I get guidance as to how to program this module exactly? Hopefully this post is in the right place.
1 year 2 months ago #92145
Replied by Chad on topic 2017 GMC Sierra 5.3L -How to program new BCM to truck
You don't do the programming with your scanner. You will use the Jbox and a laptop PC. Connect the Jbox to the laptop with a USB cable. You will need to install the Jbox drivers on to the laptop. To do this, download and install Maxi PC Suite on to your laptop. Then purchase a
subscription to SPS2
, from ACDelco TDS. After you purchase a subscription, you should see a "View" button. From there you should find a link to download Techline Connect. Installing Techline Connect will put a shortcut to the application on your desktop, but do not use it. Techline Connect must be launched from a link on the website, not the desktop shortcut.
Once Techline Connected has launched, use the SPS2 tab to program modules.
The following user(s) said Thank You: Mechanic 350
