Thermostat on Hybrid
  • Tutti57
7 years 11 months ago #25023 by Tutti57
Thermostat on Hybrid was created by Tutti57
I'm wondering if there is a good way to tell (besides pulling it) if a thermostat might be stuck open on a hybrid. The problem is that the engine does not run as often so I'm not sure how to interpret the data.
Here is an example of the mpg table as the car is driven for about a half hour in very cold temp, around 15* f.
7 years 11 months ago #25041 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Thermostat on Hybrid
I would go old school measure the temperature at raddiator top hose inlet with the by-pass (heater) hose temperature close to the cylinder head as the engine warms up from cold. You should be able to see a huge difference between the two until thermostat opening temperature is reached. I use a 2 channel K-Type thermocouple for this as they react faster than other thermometers. 2 channel thermocouple meters are very cheap on eBay and Amazon
7 years 11 months ago #25055 by Andy.MacFadyen
The following user(s) said Thank You: Noah, Tutti57
Time to create page: 0.254 seconds
