Considering buying Uscope Master Kit
- Bonehead
8 years 4 days ago #24306
by Bonehead
Considering buying Uscope Master Kit was created by Bonehead
What are some tips and tricks tutorials and such I can watch to learn how to use this scope.
Will my scope of diagnostics be limited with such a package?
Thanks!
Thanks!
- blackbart
- Thank you received: 6
8 years 3 days ago #24342
by blackbart
Replied by blackbart on topic Considering buying Uscope Master Kit
AES wave has good utube videos. Great tool although there are many times you want a sync or second channel.
7 years 11 months ago #24480
Replied by Andy.MacFadyen on topic Considering buying Uscope Master Kit
The uScope is a very handy bit of kit but the single channel is a limitation especially as cam & crank synchronization are increasingly becoming an issue. Never the less it packs a lot bang for your buck and any scope is a 1,000 better than no scope, also you can still use all of the accessories probes and clamps if you upgrade to a more powerful scope.
- Mitchroberson
- Thank you received: 12
7 years 11 months ago #24867
by Mitchroberson
Replied by Mitchroberson on topic Re:Considering buying Uscope Master Kit
I bought the uscope and day before it arrived. I needed a 2 channel scope. Ugh. So I bought a cheap 2 channel do scope For $90 used what came with the uscope and worked great. But prefer the uscope for presets.
But even with both so far. I have less invested then a larger scope. So it is a great DIY and or a great budget scope to learn on.
Would like a larger screen but figure once I get good at using it then it will be easier to justify something bigger.
Sent from my SM-N950U using Tapatalk
