Test lead extensions
- Ro-longo
- North Salt Lake, Utah
- Thank you received: 43
10 years 3 weeks ago #2748
by Ro-longo
Test lead extensions was created by Ro-longo
Found this on my local Cornwell dealers truck the other day and really like these things. They let me extend my test leads. I have seen Paul comment on the Snap-On test leads that come with the Verus being too short. I was having the same issue. I ordered two of them (they are cheap). You can find them on Amazon as well
www.amazon.com/Female-Banana-Plug-Adapter
I usually just need one on the ground connection
10 years 3 weeks ago #2763
Replied by Noah on topic Test lead extensions
I bought a power probe master kit a few years back and always use the accessories on my meter and scope.
Thanks for sharing!
Thanks for sharing!
- scott.scottmechanics
10 years 2 weeks ago - 10 years 2 weeks ago #2951
by scott.scottmechanics
Replied by scott.scottmechanics on topic Test lead extensions
Hello every one I use these red 3 way leads from power probe and the green wire piercing tool great bits of kit
Last edit: 10 years 2 weeks ago by scott.scottmechanics. Reason: Add a picture
10 years 2 weeks ago #2952
Replied by Tyler on topic Test lead extensions
I've used that green wire piercing tool, loved it. I think about buying
the piercing set
all the time, waaaaayyyyy better than the Pomona ones I have.
10 years 2 weeks ago #2968
They're pretty handy, and available individually on most of the tool trucks.
Does anyone use the Power Probe short finder? I have it, just because the set I bought on sale years ago came with it, but have had little need for it over the years.
www.google.com/url?sa=t&rct=j&q=&esrc=s&...m=bv.135974163,d.dmo
- SLCDIAG
- Thank you received: 3
10 years 1 week ago - 10 years 1 week ago #3057
by SLCDIAG
ASE Certified Master Automotive Technician + L1
ASE-5578-5149
Replied by SLCDIAG on topic Test lead extensions
(Power probe open circuit tool)
You can do the same job for cheaper with this tool. They are both "fox and hound" tools. Makes life so much easier chasing down open circuits.
Red lead goes to the circuit you want to check and black lead goes to body/chassis ground. Run the wand along the circuit with the button pressed and you will hear a tone. When the tone disappears, you found your break.
www.amazon.com/Fluke-Networks-26000900-P...=fluke+fox+and+hound
I used it the other day on a door-ajar light issue on an F-250. About $50 cheaper and it's Fluke.
-Thanks for the info on the dual male banana adaptor. I could use those.
ASE-5578-5149
Last edit: 10 years 1 week ago by SLCDIAG.
