compression testing variables
  • cheryl hartkorn
  • cheryl hartkorn's Avatar Topic Author
7 years 8 months ago #21868 by cheryl hartkorn
compression testing variables was created by cheryl hartkorn
had a 2004 grand cherokee 4.7 liter with a dead misfire. found it to be the exhaust rocker arm that came off. so the exhaust valve was stuck shut. had all cylinders with compression of 140 psi. i went with compression just by the way it cranked. the vacuum gauge looked pretty solid no bouncing or anything. is there a way you guys have to check for stuck exhaust valves? the valve cover was easy to get off but if it wasnt it would be nice to know so not much time is wasted. i was thinking maybe timing as well
7 years 8 months ago #21869 by Ben
Replied by Ben on topic Re:compression testing variables
Are you saying the cylinder with the dropped rocker had same compression as rest? All the mopars I've seen drop the rockers were caused by the valve seats falling out of the head and holding the valve open..
7 years 8 months ago #21870 by Ben
7 years 8 months ago #21871 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic compression testing variables
Short of an in-cylinder pressure test watching the gauge on old style compression test with the Schrader valve removed should show a difference in the way the needle moves it should bounce twice as fast because there is an extra compression peak on the exhaust stroke.
A First-Look pressure pulse test on the exhaust or inlet should show something but interpreting First-Look tests to diagnose a particular fault isn;t easy.
  • cheryl hartkorn
7 years 8 months ago #21877 by cheryl hartkorn
Replied by cheryl hartkorn on topic Re:compression testing variables
yes ben. same result as the rest
7 years 8 months ago #21881 by bruce.oliver
Replied by bruce.oliver on topic Re:compression testing variables
Relative compression with a scope would show it. If the exhaust valve is closed you would basically have 2 compression strokes on that cylinder. So on the relative compression you would have one peak much higher than the rest because you would have 2 cylinders at peak compression at the same time. I will post a picture of a scope capture later today or tomorrow
  • cheryl hartkorn
7 years 8 months ago #21882 by cheryl hartkorn
i could tell there was an issue during cranking. at the time i dint know if it was out of time or if it was a compression issue at the time. vacuum gauge was super steady at idle no fluttering or anything i was taking vacuum at the brake booster
7 years 8 months ago #21972 by bruce.oliver
Replied by bruce.oliver on topic compression testing variables
Added a pic from a class I took in Pennsylvania. It shows relative compression from a 2002 Dodge 4.7 with a #2 misfire. See how how the #3 compression is? That's because the exhaust rocker on #2 is off causing the misfire. When #3 is at TDC of compression #2 is at TDC of the exhaust stroke. But with the exhaust rocker off that puts compression on #2 and #3 at the same time. Which is why#3 is so much higher than the others on the relative compression test
7 years 8 months ago #21984 by Andy.MacFadyen
Nice capture
7 years 8 months ago #21985 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Re:compression testing variables
cheryl hartkorn wrote: i could tell there was an issue during cranking. at the time i dint know if it was out of time or if it was a compression issue at the time. vacuum gauge was super steady at idle no fluttering or anything i was taking vacuum at the brake booster
I never really learned the skill of using a vacuum gauge as it was not useful on the engines I learned on which were mainly 4 cylinder twin carb.
7 years 8 months ago #22018 by Tyler
Replied by Tyler on topic Re:compression testing variables
I've seen the same thing as Bruce on a relative compression waveform. This is my go-to test when I think a rocker arm fell off a 3.7/4.7 engine. I used to go in-cylinder to prove it, now I just sell valve cover labor. :lol: Nice job going with your gut and the cranking sound.
I'm really surprised your vacuum gauge was steady, Cheryl. :huh: It's gotta be dumping 100+ PSI into the intake when the intake valve opens... Why doesn't the vacuum gauge notice?
7 years 8 months ago #22022 by Andy.MacFadyen
Tyler wrote: I've seen the same thing as Bruce on a relative compression waveform. This is my go-to test when I think a rocker arm fell off a 3.7/4.7 engine. I used to go in-cylinder to prove it, now I just sell valve cover labor. :lol: Nice job going with your gut and the cranking sound.
I wonder if the brake booster vacuum take off had the one-way check valve built in atthe manifold end ? butsurely even then I would have expected some pulsing on the gauge.
