Nissan Murano Cmp&Ckp waveforms
(I forgot my Verus at the shop, but will upload better waveforms when I have the chance...)
Crank no start, single spark event, 3-4 injector pulses, then no control.
After a long crank, sets codes for bank one cam sensor circuit fault, bank two cam sensor circuit fault, crank sensor circuit fault.
All three sensors are 12v, 3 wire hall effect sensors.
Power, ground and signal at all three are good and consistent during cranking.
At this point, I want to see if there is a correlation issue.
As luck would have it, Nissan supplies a sample waveform in the service info!
My waveform appears to be off, but beside not lining up, the cam sensor seems to generate the opposite signal...
Yellow B2 CMP (front bank)
Green B1 CMP (rear bank)
Blue CKP
Note that the sample shows that the signal goes from low to high, where as mine goes high to low...
I just happened to have a perfectly good running 2005 Nissan Murano on the lot, so I parked it behind the no-start Murano and hooked up the leads exactly the same and plugged in the scope without changing any settings.
This wave form matches the sample from Nissan.
So what's the deal No-start-nissan?
Why is the signal apparently inverted on the problem vehicle?
I'll be happy to e-mail the .vsm files to anyone who would like to view them. I am thoroughly confused, and welcome discussion!
The weird part is that some cars get away with it and have no issues. Weird, right? Depending on the YMM, the PCM only looks at where the transitions occur, and doesn't really care if it's high/low/whatever.
I'm on my phone, so it's tough to see, but how's the revelationship on the problem vehicle? If it seems OK, I'd be confident in at least doing cam sensors, if not all three.
I am tempted to take the sensors from the running car and put them in the dead one to see if the polarity is corrected, but I still don't think it will run.
I have never heard of this phenomenon! I'm seriously glad I had a running vehicle to compare to.
At first I assumed that regardless of the polarity, the transition would occur at exactly the same time. But if the signal is truly inverted, would the leading edge of the transition just swap with the trailing edge, or could the transition be advanced?
If you retard each inverted cam transition on the problem vehicle by the exact width of the transition, they would fall within the synch window of the crank signal.
I was editing captures to include 720 degrees of rotation to post when I noticed this.
If course the battery died on my computer before I could finish, but I think you can see what I'm referring to in the pics posted before.
First is the known good: It looks like the signal "flips" part way through the pattern ch1. Weird... So I guess my late night hypothesis about the possibility of the signal being inverted and therefore possibly "reversed" was incorrect.
Ch1 Yellow B2 CMP
Ch2 Green B1 CMP
Ch3 Blue CKP
Next is the no start with the inverted cam sensor signals:
Ch1 Yellow B2 CMP
Ch2 Green B1 CMP
Ch3 Blue CKP
And finally, the example from Nissan:
My curiosity got the best of me, so I did go in early put the known good sensors in the no start Murano. As I suspected, it was still a no start, but once I had it in my head I had to try it
Unfortunately it was raining this morning, and the cars were outside, so no scope captures of that experiment. :blush:
I'm interested to see how many more instances of this "signal flipping" I'll come across considering there seems to be an uncomfortable number of these Nissan 3.5l powered vehicles coming through the shop. Hoping someone has some input considering what causes this occur.
- Charles Acosta
- Thank you received: 13
I've been reading about other similar instances on iATN. No one really seems to have a solid answer as to the "why" it happens.
Some say that it can be attributed to low voltage and low cranking speed. Sometimes it happens with a no start, sometimes it happens with a code and sometimes it has no effect on operation. But who would be looking at the signals for a grin unless there was a code or symptom leading them there?
It does seem that regardless of the "flip" the sync pulses should always align. At least from what I've been able to gather. I am curious if it could have a negative effect on ignition timing.
I think there's another Murano coming in for AC service this week. I want to check that one out too, cranking clear flood and running.
- edicola12
See this attached ... I don't think you have a problem with sensors or timing but with wires back to computer or computer itself
I did NOT finesse the alignment study of cmps to ckp so maybe they are off - also without seeing the whole waveform I cannot judge it fully - I am making assumptions - but I hope you see my drift and take it into a more clinical view/assessment
- edicola12
Thank you for taking the time to respond to this topic.edicola12 wrote: I take take that back - after a re-look I see Bank 2 could be off
I'm confident that the timing is off and the cause of the no start. From what I can see the cam events never align with each other or the crank events, especially if the trailing edge is truly the "signal" the PCM waits to see as had been suggested.
The inverted signal kind of made me question my understanding of how these sensors generate signals and how the PCM interprets them.
The more I read about it, the less important it seems to be, but something to be aware of none the less.
- edicola12
Good luck keep us posted
Noah, I just now noticed the stuff you have written in paint marker on the top of your Verus. :lol: Any more info written elsewhere?
Every where!Tyler wrote: Great stuff edicola12.
Thanks, sir!
- juergen.scholl
- Active partschanger
- Thank you received: 462
would the engine start with cam sensors unplugged?
- mario.garcia
did you solve your problem?
I have exactly the same case with a 2011 Nissan Murano 3.5
The timing belt looks out of time.
and the inverted signs,
Also cmp 1,2 ckp never align.
Can you give me advice about your situation?
greetings
Coahuila México
I did spend a good deal of time researching the cause of inverted sensor signals because of that engine.
It seems to be something that does happen time to time, not just on Nissans. I've read a lot of half baked theories on why, and none of what I've read has really given me any more clarity on the situation.
Some engines it happens and the car runs fine.
Bernie Thompson has some videos with inverted sensor patterns, that he blames on magnetized camshafts/crankshaft reluctors. I have a great deal of respect for Bernie and what he has done for this industry, but I am not sold on his theory as far as that is concerned.
- mario.garcia
I did a lot of research on the subject and found that it totally depends on the confirmation of the sensor and that to me is completely logical.
I will do tests with different sensors and share the results.
For the moment I will look for the chain's phase shift point.
