secondary spark concerns
- DIYGUY
8 years 5 months ago #20656
by DIYGUY
secondary spark concerns was created by DIYGUY
- Scottpitcher22
8 years 5 months ago #20666
by Scottpitcher22
Replied by Scottpitcher22 on topic Re:secondary spark concerns
Do you have a misfire on this cylinder! Looks to me (I may be wrong) from my experience I’d say you may have a spark leaking to ground before spark plug
- DIYGUY
8 years 5 months ago #20676
by DIYGUY
Replied by DIYGUY on topic Re:secondary spark concerns
It is not xlsetting a misfire code, but it does seem to have some misfire to it.
I will get a new distributor cap and tune it up.
8 years 5 months ago #20694
Replied by Andy.MacFadyen on topic Re:secondary spark concerns
A lot of energy left after the spark look at the spark plug gap and issue in the plug lead and HT side of the coil
- DIYGUY
8 years 5 months ago #20697
by DIYGUY
What is the normal KV output of a distributor type coil? I have to go to my biggest KV scale to get it to fit on the screen.
That was on the # 1 cylinder, last night I did replace the spark plug with a new one. The old one had a .042 gap. Factory spec is .039" to .043". I checked the plug wire to make sure it seated good on the plug and cap. The cap end seemed a little loose. I inserted the wire more and rechecked the spark waveform. i will try and post it.
- DIYGUY
8 years 5 months ago #20698
by DIYGUY
