CD ignition primary test possible
- 1mouse3
- Thank you received: 4
10 years 1 month ago #2242
by 1mouse3
CD ignition primary test possible was created by 1mouse3
for a msd 6a/6al or any other capacitive discharge ignition, is it possible to capture a primary ignition waveform or is it just the secondary that is possible.
10 years 1 month ago - 10 years 1 month ago #2244
Replied by Andy.MacFadyen on topic CD ignition primary test possible
Yes if you scratch around on the web there are a couple of pages with primary capacitive wave forms the only problem with connecting straight to the primary is the voltage, some scopes would be fine with a 20:1 attenuator but high voltage 100:1 and even 1000:1 probes are available fairly cheaply. However you would need to first establish what a good waveform looks like. The same goes for primary current you would need to capture a known good to spot a bad one.
The secondary is easier to deal with a normal spark line even a multiple spark line voltage is going to be determinded by the plug gap, mixure, compression, throttle openning the same as any other spark line.
Last edit: 10 years 1 month ago by Andy.MacFadyen.
- 1mouse3
10 years 1 month ago #2253
by 1mouse3
Replied by 1mouse3 on topic CD ignition primary test possible
fair enough, a CD system's primary is not a good place to look for problems and the secondary is the best route to travel
10 years 1 month ago #2255
Secondary is certainly the easiest place to start.
