Testing a relay
  • bruce.oliver
  • bruce.oliver's Avatar Topic Author
8 years 7 months ago #18624 by bruce.oliver
Testing a relay was created by bruce.oliver
How do you test a relay?
The instructor in one of my classes at Vision said the proper way to test a relay was to remove it, apply power and ground to the control side and then check resistance through the load side. I don't think I like that idea.
8 years 7 months ago - 8 years 7 months ago #18630 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Testing a relay
That test isn't going to give you a result you can have great confidence in and it isn't going to be a quick and easy test to do. A relay or switch needs to be tested at near its' working current . Which is why there are a variety of by-pass tools and breakout tools for testing relay circuits.
I have relay tester I picked up in a Maplin clearance sale but it is also is of limited value -- it tests the relay is switching over repeated cycles but doesn't load the contacts to a representative load.
I keep a selection of known good relays in my tool drawer --- with relays swaptronics is sometimes the quickest easiest test.
Last edit: 8 years 7 months ago by Andy.MacFadyen.
  • bruce.oliver
8 years 7 months ago #18671 by bruce.oliver
Replied by bruce.oliver on topic Testing a relay
I agree 100%
