solus to ultra pro
  • Ben
  • Ben's Avatar Topic Author
8 years 7 months ago #18612 by Ben
Re:solus to ultra pro was created by Ben
The software doesn't expire? Suretrack is a common parts identifier for the particular dtc your dealing with and it has to be renewed if you choose to use it (I let mine expire never found it very helpful) otherwise the actual diagnostic software doesn't stop working
8 years 7 months ago #18717 by GypsyR
Replied by GypsyR on topic Re:solus to ultra pro
I believe someone is mistaken. More that a few of us have woefully outdated scanners and such that work just fine. You just won't have info on newer vehicles, like where the crank sensor is and hints on how to test it. Stuff like that. You can still look that info up somewhere else and use the Modis to check it just the same though.
8 years 7 months ago #18891 by Tutti57
Replied by Tutti57 on topic Re:solus to ultra pro
Right, you'd just only have access to information up to that last update.
8 years 7 months ago #18917 by GypsyR
Local Snap On rep verified it. The image Apache posted earlier is a message you can get when the scanner has shut off a VERY long time or someone attempted to do an update that didn't belong to that machine. It goes away and then you go back to using as before.
The following user(s) said Thank You: apache4trak
Time to create page: 0.345 seconds
