Fuel Injector Cleaneing
  • Charles Acosta
  • Charles Acosta's Avatar Topic Author
8 years 8 months ago #18480 by Charles Acosta
Fuel Injector Cleaneing was created by Charles Acosta
Hello. I"m considering getting the OTC injector cleaner to service my injectors. I can disable the fuel pump by opening the inertia switch. My system is a mechanical return less type so I wanted to know is the procedure any different than a system with a return line. I've seen videos on Youtube but with return line systems. Thanks.
8 years 8 months ago - 8 years 8 months ago #18491 by Tyler
Replied by Tyler on topic Fuel Injector Cleaneing
I've never used the OTC cleaner, but I figure you're referring to this one?
www.otctools.com/products/fuel-injection-cleaner-canister
If I'm reading the manual correctly, I think they just want you to disconnect the pressure line from the rail, and connect the canister in its place. With the pump disabled, you can let the disconnected pressure hose hang out during the service. Dial the pressure up to whatever spec is and let it go!
Last edit: 8 years 8 months ago by Tyler.
8 years 8 months ago #18523 by Ben
Replied by Ben on topic Re:Fuel Injector Cleaneing
I haven't used the otc ,but I have the motorvac fuel cleaning machine and it's easier on the returnless system , I usually just pull the fuse to the fuel pump so the scanner doesn't time out during cleaning and pump fuel everywhere! (It takes about 30 mins to complete)
8 years 8 months ago #18524 by Tyler
Replied by Tyler on topic Re:Fuel Injector Cleaneing
Oh, you kill the pump? I just deadhead it. :lol: Always how I've been told to do it, maybe I'm an ape.
8 years 8 months ago #18529 by Ben
Lol poor pump !
8 years 8 months ago #18530 by Ben
On return systems I don't kill the pump I look it back through the fuel return but I always kill the pump on returnless systems
8 years 8 months ago - 8 years 8 months ago #18532 by Tyler
Ben wrote: On return systems I don't kill the pump I look it back through the fuel return but I always kill the pump on returnless systems
Definitely agree on the return systems. I think that's outlined in the machine manual, IIRC.
But in all seriousness, am I wrong to rely on the regulator in the tank on returnless systems? :huh: Maybe 'deadhead' wasn't the right choice of words. I just block the pressure hose and let the regulator in the pump do its job.
8 years 7 months ago #18581 by Ben
For returnless systems with a regulator in the tank I don't see any reason why you couldn't block the fuel line, but for returnless vehicles with Pwm fuel pumps that would probably be a near horrible death for them!
  • Charles Acosta
8 years 7 months ago #18589 by Charles Acosta
Replied by Charles Acosta on topic Re:Fuel Injector Cleaneing
I spoke to the tech support rep from OTC and he says as long as the inertia fuel switch is open which doesn't allow the FP to run, I should be ok with cleaning the injectors. Since I have a schrader valve on the fuel rail there is no need to block or tap into.
8 years 7 months ago #18615 by Ben
I agree with inertia switch being a suitable way to disable fuel pump
Time to create page: 0.455 seconds
