Coil on Plug probe
8 years 9 months ago #16937 by Pinto
Coil on Plug probe was created by Pinto
I need recommendation on a probe for testing secondary ignition output, I want to use it with Modis scanner as well as pocket sized mini oscilloscope.
8 years 9 months ago - 8 years 9 months ago #16945 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Coil on Plug probe
The two major ones are the Pico and the Wyze , Hantek also make one but it costs almost as much as the Pico or the Wyze --- check out the tools section of scannerdanner.com as AES Wave sell both Pico ans Wyze You may need a BNC to Banana socket adapt.
Auto-Ditex make a lower cost one but it is a different configuration and not as useful.
Last edit: 8 years 9 months ago by Andy.MacFadyen.
The following user(s) said Thank You: Pinto
8 years 9 months ago #16950 by arbez
Replied by arbez on topic Coil on Plug probe
I have one of these:
smile.amazon.com/OTC-Tools-3825-56-Unive...1&keywords=cop+probe
I have had it for years & it works OK. I have never used any others, so I don't have anything to compare to, but this one works just fine. I believe it was less than $40.00 when I purchased it. It has gone up at least $20.00 everywhere I looked.
Before I bought that one I used this tip form Real Fixes Real Fast:
I used the pickup from my original Vantage meter & that worked OK also.
The following user(s) said Thank You: Noah, Andy.MacFadyen, Pinto
8 years 9 months ago #16974 by Pinto
Replied by Pinto on topic Coil on Plug probe
Looks like the OTC probe you linked above can get to hard to reach coils. I will get one soon..Thank you guys
