Piezo injectors
- scopeman
- Thank you received: 3
8 years 11 months ago #15387
by scopeman
Piezo injectors was created by scopeman
How can we determine which petrol car is using piezo injectors ,is there a way to know by looking under the hood and seeing the injectors (if possible) and telling them apart from solenoid ones? Reason i ask is when using the timer tool to test injectors we need to know which ones they are .Are only GDI engines using them ? i have had a look around the web but cannot seem to find out.Also i have autodata and haynes pro but neither of these give much info regarding the injectors.Any info appreciated .
8 years 11 months ago #15394
Replied by Andy.MacFadyen on topic Piezo injectors
The only 100% certain way I know so far is to scope them put a current clamp on them and they are very distinctive --- we will learn as we encounter more.
- scopeman
8 years 11 months ago #15434
by scopeman
Replied by scopeman on topic Piezo injectors
Managed to find a bit more info on the web regarding piezo injectors.
www.techtips.ie/Autobiz/testing-piezoelectric-injectors-1.pdf
